Author Topic: Holes on left side of trunk floor  (Read 4561 times)
BOTIGER1970
  • USA, NC, Mooresville
« on: February 01, 2023, 00:46:16 »
Does anyone know the size of the two holes for the fuel vapor canister plastic pipes on the left side of the trunk floor just back of the wheel well on the 1970 280SL?  I replaced this piece, but it didn't come with the holes and my part was rusted away at the holes.  I also don't have the grommets and am not sure which grommets are correct for my car.
Leester
  • USA, VA, Lorton
Re: Holes on left side of trunk floor
« Reply #1 on: February 02, 2023, 02:16:47 »
You will need two grommets: 110 997 14 81 and 108 471 00 81. I bought both from Authentic Classics. I used a step drill and checked the hole size frequently. If you need to know where the holes go, there are photos on Motoring Investments but you have to look through the various cars listed on their "old" website.
Lee Backus
1963 220SE Cabriolet
MikeSimon
  • USA, OH, North Royalton
« Reply #2 on: February 02, 2023, 13:02:59 »
Does anybody know whether this vapor canister was on Euro (German) models also? I cannot find any evidence of this ever being on my car. I know some countries had a regualtion that you could not vent the tank to the atmosphere, but Germany did not have this.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Jordan
  • Canada, ON, Jordan
« Reply #3 on: February 02, 2023, 15:38:59 »
Mike, if you are referring to the fuel vapor expansion tank in the trunk (passengers side), then yes, my late 230SL, German delivery, has such.
Marcus
66 230SL  Euro 4 speed
« Reply #4 on: February 02, 2023, 15:55:36 »
Mine is on the right side--passenger side--when standing at the back of the car.
It is more of an expansion tank than anything else, as it is open to the atmosphere via the FST (funnel shaped thing) which is one of the three connection points on the canister.
If my memory serves me correctly, two lines from that expansion tank connect to small steel lines on the fuel tank. If the fuel expands or evaporates in the tank, it "overflows" into that expansion tank. If the  expansion tank gets too full, it drains out the FST...or something similar.
When I restored my car, my original expansion tank had small brass tubes as connection points, and fuel-grade hose connected these points to the points on the fuel tank, while the third one went to the FST. I had, when they were exceeding cheap, bought the MB OEM replacement. Imagine my surprise when it seemed to be a one-pieced molded thing of exceeding lower quality than the one I had. So, I didn't install it. What I did do was cut it open! Nothing inside. No carbon filters or anything. It's merely an expansion tank much the same as the one for your radiator in the engine compartment.
Mine's a January 1969 build, so emissions regulations may have changed to something different after that time.
MikeSimon
« Reply #5 on: February 02, 2023, 16:43:23 »
My car does not have it and I can see no evidence it ever did. No empty holes, no loose lines or tubes.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #6 on: February 02, 2023, 17:25:37 »
The emissions regulations changed for the US for the 1970 model year. My 280 SL is a Sept 69 build but built to model year 1970. It has the larger expansion tank in the left side trunk well, with the two holes as mentioned by the original poster.
This was more an "emission reduction" system than an emission control system. There are a number of relays (two are elecrtronic) and valves to route vapor and fuel flow back to the engine.
There is a description of the system and diagrams in the technical manual - Go to the tech manual, scroll down to "Fuel system" click there and scroll down to "Emissions Control System"
Jordan
« Reply #7 on: February 02, 2023, 17:39:13 »
Assuming we are talking about the same thing here is a pic of mine.  There are clips on the hard board to hold the tank in place and direct the vapor lines.
Marcus
MikeSimon
« Reply #8 on: February 02, 2023, 22:18:38 »
Don't have it.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
BOTIGER1970
« Reply #9 on: February 02, 2023, 22:33:14 »
My research shows that the change in the U.S. from the right side canister to the larger vapor Canaster that was placed on the left side was for VIN 11948 and up; was a change for U.S. cars.  If I understand this correctly the U.S. had different emission requirements then Europe.  The hole sizes I asked about in my original post would only be on the cars that had the larger vapor canister on the left side.
BOTIGER1970
« Reply #10 on: February 13, 2023, 03:40:36 »
I received info from MB Classics concerning the hole specs for the left side of the trunk.  Thought I would pass on incase some else needs the information.
-Hole center to hole center is ~35mm
-Bigger hole diameter:  ~25mm
-Smaller hole:  ~20mm
-Distance between the two holes:  ~15mm
AdelaidePagoda
  • Australia, South Australia
« Reply #11 on: February 13, 2023, 08:48:36 »
MikeSimon, my Jan 64 Italian delivered 230SL has the fuel expansion tank.
Dave
January 1964 230SL 4SPD Power Steering
050 050 Black Soft top, Red Leather interior
Italian delivered/ Germany/ Florida/ Boston/ Sydney/ Adelaide (5th owner)
Model S Tesla
Vespa
