Author Topic: Master Brake Cylinder  (Read 2527 times)
larryled
  • USA, VA, Alexandria
« on: January 17, 2023, 19:34:08 »
Need info/video on rebuilding the Master Brake Cylinder on 60’s Benz.  Thanks, Larry L.
Vander
  • USA, OH, Columbus
Re: Master Brake Cylinder
« Reply #1 on: January 17, 2023, 20:13:55 »
What year or model? The early cars have different master cylinders than the later cars. Unless you think it will be a fun learning experience, the master cylinder is a part that you may prefer buying. It's pretty reasonable, especially the later cars.
larryled
« Reply #2 on: January 17, 2023, 20:25:33 »
It’s a 1966 250SE/C.  I already have a rebuild kit;  the brake peddle goes almost to the floor and will not pump up, no leaks of fluid noticeable from the calipers etc..   LLLL
Kevkeller
  • USA, HI, Honolulu
« Reply #3 on: January 21, 2023, 15:59:29 »
I would think it’s a pretty generic job. There’s probably many videos on Youtube you can look at.
1970 280 SL
WRe
« Reply #4 on: January 21, 2023, 17:13:07 »
you'll find some videos on youtube, it's pretty straight forward, most MBC looks the same.
https://www.youtube.com/watch?v=WYB4vOv7Iag
Just remove the retaining ring and slide the pistons out. Remove the (cup) seals and renew them.
...WRe
« Reply #5 on: January 21, 2023, 19:31:23 »
I won't rebuild a MC unless I have no other options. It's very difficult to reproduce the mirror finish inside the cylinder and without that they tend to leak. Plus I have to consider liability.
