Author Topic: Hood rod tension  (Read 2417 times)
getsmart
Hood rod tension
« on: November 03, 2022, 02:24:34 »
Hello all,
I'm up to installing the hood tension rod and reading the many previous posts on this subject I can see that some have had to do a full 360° tension on theirs whilst others only 180°.
Obviously the tension bars appear to be of varying strengths but I also wonder if the earlier rods also have different angles between the right and left.  You can see on mine when on no tension my left and right are more than 90° apart whilst I've noticed on others the angles are almost the same.
Not sure if I'm keen at all on doing a 360° tension on mine!!!!
Thoughts anyone?
Rgds, Joe
Ps, red photo is mine and the black is from another
« Last Edit: November 03, 2022, 03:21:16 by getsmart »
Finding the red car
getsmart
Re: Hood rod tension
« Reply #1 on: November 03, 2022, 22:18:07 »
seems like my answer is located in this thread
https://www.sl113.org/forums/index.php?topic=17938.25
450 degrees rotation needed!!!!!  :-[ :-\
« Last Edit: November 04, 2022, 22:35:20 by getsmart »
Finding the red car
