Author Topic: Heater lever lights  (Read 4153 times)
EdwardBernard
  • Canada, AB, Edmonton
Heater lever lights
« on: July 08, 2022, 17:12:10 »
Hi everyone,
   Restoration continues! I already installed LED bulbs into my heater lever assemblies but nothing lights up yet. Examining the wiring, I note that the driver's side has a hookup to a wiring plug while the right-hand one doesn't (see the blue lines). However, there are two wires connecting the two, as indicated with the circled area. Does anyone know if this is the usual setup, or has something been previously modified?
Thanks, as always--
Bill  :)
Bill Leddy, Edmonton, AB, Canada
1964 230 SL, red, manual, ps
WRe
Re: Heater lever lights
« Reply #1 on: July 08, 2022, 18:00:16 »
« Reply #2 on: July 10, 2022, 03:12:10 »
The same rheostat that dims your other instrument lights also regulates the heater control lights. Check to see if the lights work in the other instruments first.
EeVeeWee
« Reply #3 on: July 10, 2022, 07:18:16 »
This a picture I made some time ago.
Again something else.
« Reply #4 on: July 10, 2022, 13:02:38 »
Normally your assembly will have only one provision for a plug. Most likely someone previously changed to two plug units. This should not be the problem.
dirkbalter
  • USA, CA, Corona
« Reply #5 on: July 10, 2022, 16:47:14 »
Mine looks the same as above. I was under the impression that the black housing is the same for both sides but only one side connected?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #6 on: July 11, 2022, 09:33:34 »
My 64 230 has same. This is early version.
1964 230SL
EdwardBernard
« Reply #7 on: July 11, 2022, 16:32:30 »
Thank you, all! Most reassuring and helpful.  :)
getsmart
« Reply #8 on: July 18, 2022, 09:08:18 »
On an early 230sl (mine has a pair of prongs) I think the supply goes to one and then power is supplied from the 2nd pair to the lighter
Finding the red car
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
« Reply #9 on: July 19, 2022, 12:03:29 »
Here is how it's on my car:
(erase the comments.....! coming from another thread)
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
getsmart
« Reply #10 on: July 21, 2022, 01:02:20 »
This is my setup
Finding the red car
Paul & Dolly
  • i Car
« Reply #11 on: July 21, 2022, 01:10:32 »
I don't think the cigarette lighter ,which is a high power user, should be connected to any lighting circuit, it could well burnout the rheostat for the instrument lights.
Keep well
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
getsmart
« Reply #12 on: July 21, 2022, 01:23:38 »
Hey Paul you're correct,  cigarette lighter power comes straight off the ignition.  The 2nd pair of connectors on my heater control must be spare....
Also it's 1.5 gauge according to the circuit diagram.  Thanks, not sure why I forgot to consult the circuit diagram!!!
Finding the red car
