Author Topic: Pagoda Oil Leaks  (Read 25122 times)
Re: Pagoda Oil Leaks
« Reply #25 on: June 10, 2005, 15:00:14 »
this thread has great info about idle problems
http://index.php?topic=160,regulator
« Reply #26 on: July 06, 2008, 11:16:58 »
I discovered the source of my oil leak this morning: turned out to be the small oil pressure gauge tube, right where it connects to the top of the oil filter housing. It's a 14 mm nut that connects 'garden-hose-style' to the small, fairly hard, plastic tube that goes through the firewall to the oil pressure gauge.
With the engine running, there was a drop of oil coming out every second! That's a small puddle fairly quickly. I tried cutting off the end piece of the plastic hose to reconnect a fresh section to see whether that would cure it, but I could not manage to refit the plastic hose onto the metal fitting, even after having it sit in boiled water for a minute or so - that's how hard that plastic is (or has become).
I will order a complete new hose-with-fittings tomorrow and in the meantime I capped off the opening on the oil filter housing so I can continue driving the car in the meantime. No oil pressure reading of course (looks strange - but then again, I have never in my 9 years of ownership had an oil pressure problem).
« Last Edit: July 08, 2008, 04:00:51 by 280SL71 »
« Reply #27 on: July 07, 2008, 22:20:06 »
One possibility with rear axle leaks is that they are actually coming from the front - or at least so a veteran mechanic told me last week: while driving, a leaking engine keeps leaking and the oil that normally falls straight down will travel to the rear of the car (making that oily); when you park it, it drops on the floor there.
Gotta love an answer like this one. The guy who told you this one really wasn't thinking. If your engine was leaking that much oil it would be all over the place and not just on the rear axel.
A small amount around the axel is coming from the axel and not the engine.
As if.......( lol )
BourbonBob
« Reply #28 on: July 15, 2008, 12:24:35 »
I believe that my oil hose connecting to the oil cooler is leaking. There's two, haven't figured out which one, and haven't found anyone with replacement hoses.
Bob Krejci
68 280SL #001640
« Reply #29 on: July 15, 2008, 15:07:37 »
SLS in Germany lists both of these at around EUR 30, so they should be avaiable in the US as well. Although I don't see a reference for the late version upper hose for the 280 SL normally this should be available. If not, you should be able to find a used one that may hold out for many more years.
BourbonBob
« Reply #30 on: July 17, 2008, 08:00:29 »
Found the leak (and hopefully the new part). Top hose(oil is sitting on top of the battery) and it's leaking at the metal fitting/hose connection. German Auto Parts and AutoAZ have the part(under $30).
Bob Krejci
68 280SL #001640
bjudd
« Reply #31 on: September 15, 2008, 17:08:39 »
Originally posted by A Dalton
 Eng oil is also best level when 1/2 way mark at warm engine after 5 min drain time lapse...
This is a little confusing.  I have been filling to the top of the line with the engine cold.  Am I overfilling?
thanks,
