Author Topic: Vacuum retard regulator Bosch 051  (Read 2999 times)
Runale
  • Malta, L-Iklin, Iklin
« on: April 05, 2022, 15:00:47 »
Hi all,
I am running a check on all ancillary components and found this regulator on the distributor to be stuck.  Basically it wont move and probably didnt move for the last 20 years or so. And i also noticed the the vacuum pipe had liquid in it!
Anyone has ever dismantled the unit ?? (not the distributor as seen in the technical manual)  but the actual vacuum regulator in its interior components.
Hopefully i can spare myself purchasing a new one!
Alessandro
1967 250SL G050 G040
1979 W123 200D
2019 DB11 AMR
Re: Vacuum retard regulator Bosch 051
« Reply #1 on: April 05, 2022, 15:10:15 »
The vacuum cell is a sealed unit and can not be taken apart. You will need a used one - I doubt new ones are available. You would be loosing 10 degrees of advance without it.
« Reply #2 on: April 05, 2022, 15:24:13 »
May want to consider going to 123.
« Reply #3 on: April 05, 2022, 15:36:32 »
I don't think the advance is available new either. Could probably find used a unit but.....The 123 is a good solution as Pawel suggested and has a vacuum port.
« Reply #4 on: April 05, 2022, 16:46:11 »
x3 on the 123.
I did manage to source a NOS vacuum cell for the very similar Bosch distributor in my '71 Volkswagen last year, so they are still around here and there. The old one was frozen as well. The person I bought it from has several more - but there are subtle differences so the spec/specific type is important. Once installed, the car ran much better (duh!).
You will undoubtedly notice a marked improvement once you have the additional advance in your Pagoda.
dirkbalter
  • USA, CA, Corona
« Reply #5 on: April 05, 2022, 17:18:40 »
123x4
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Runale
« Reply #6 on: April 06, 2022, 11:39:54 »
Thanks.
Alessandro
1979 W123 200D
2019 DB11 AMR
