Author Topic: Water Coming in Near Pillar B  (Read 4942 times)
« on: March 13, 2022, 19:14:05 »
After very heavy rain or, like yesterday, after heavy rinsing while washing I have this piece of carpet wet. How is water getting there?
Soft top was up. But I have all the drain hoses and drain holes working there, at the bottom of pillar B.
Somehow through the door or door seal?
Re: Water Coming in Near Pillar B
« Reply #1 on: March 14, 2022, 15:31:20 »
I would suspect the door seal as a good place to look. I had a similar issue years ago, and found that the door seal was not living up to its name!
« Reply #2 on: March 14, 2022, 17:00:30 »
Thank you, will look again...
Probably a water test...
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: March 14, 2022, 19:28:53 »
Not that it is important and contributing to the issue, but I was always of the opinion, that 2-door cars do not have a B-pillar. The A-pillar being behind the windshield and the C-pillar at the rear, a 2-door has only A and C pillars. B-pillar is between doors.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #4 on: March 14, 2022, 21:34:33 »
Respect that.
If you could take it to the next level and suggest how should I call that... thing that is there, where my water ingress is and everybody calls  b-pillar?
dirkbalter
  • USA, CA, Corona
« Reply #5 on: March 14, 2022, 22:35:07 »
Pawel,
Don’t believe everything Mike says. Lol
https://en.m.wikipedia.org/wiki/Pillar_(car)
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
MikeSimon
« Reply #6 on: March 16, 2022, 15:41:35 »
 ;D ;D Yes, it is a subject of much discussion...
Pillars are implied, whether they exist or not; where a design's greenhouse features a break between windows or doors without vertical support at that position, the non-existent pillar is "skipped" when naming the other pillars. Thus a two-door hardtop or a three box designed coupé could have its rearmost pillar called the C-pillar even in the absence of a B-pillar.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #7 on: March 16, 2022, 16:06:00 »
ok.
But if I wrote I had water near pillar C, nobody (except you perhaps) would know what the hell I am talking about or what do I smoke in the best case...
zak
« Reply #8 on: March 16, 2022, 20:38:14 »
Pawel, is it only wet on the carpet and there is no evidence of water higher up in the interior ?
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
« Reply #9 on: March 16, 2022, 21:10:17 »
Zak, nothing. Anywhere else.
« Reply #10 on: March 17, 2022, 03:03:21 »
What about under the parcel shelf?
« Reply #11 on: March 17, 2022, 06:23:40 »
Parcel shelf - sorry, which shelf do you mean, I am not sure?
I was specifically checking the interior for water leaks several times, I found a leak some time ago where water came alongside the windshield washer hose - eliminated that. Now it is dry everywhere except that carpet spot.
MikeSimon
« Reply #12 on: March 17, 2022, 13:33:36 »
I think, sometimes the area behind the seats (with the wood board covers) is called "parcel shelf" ??
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #13 on: March 17, 2022, 15:46:55 »
Thank you, I will check beneath the wood boxes - maybe there is something there...
« Reply #14 on: March 17, 2022, 18:41:53 »
Sorry Pawel, I should have been more  specific.
It is actually the compartment next to the space under the wooden box that could be the culprit. The harness cable runs along this side and I remember reading somewhere that a member found a spot for water penetration there. Incidentally, that compartment should also be sealed off with a plastic sheet.
Hope you find the source. 🤞
« Reply #15 on: March 17, 2022, 19:54:50 »
Thank you Alfred! I have been checking (dismantling everything) in that area when I was working on hollow spaces waxing and drains. It was all ok. Foil is there. But I will look again - thank you for the tip!
« Reply #16 on: April 02, 2022, 23:02:58 »
Have you found the leak?
« Reply #17 on: April 02, 2022, 23:40:13 »
Thank you for your kind attention, Alfred. I will look into that during the next car washing. Not too much driving so far this year... We have a beautiful winter this spring (attached).
Leester
  • USA, VA, Lorton
« Reply #18 on: April 04, 2022, 00:56:59 »
Very scenic although I suspect you would like to see it a little warmer by now.
Lee Backus
1963 220SE Cabriolet
neelyrc
  • USA, AL, Birmingham
« Reply #19 on: April 04, 2022, 02:51:34 »
Beautiful “Spring” photo Pawel!  I do hope you get some relief soon.  We have been a little more fortunate in Alabama.  Out for a spin this afternoon.
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
« Reply #20 on: April 04, 2022, 06:09:01 »
The previous Sunday was already ok here!
