Author Topic: option code Ho. MB-LEDER TWIN  (Read 5053 times)
john123
  • USA, NY, Smithtown
« on: January 21, 2022, 16:07:52 »
On the data card for my 66 230sl  box #22,  which is often labeled Scheibenwischer (windscield wiper), it is not labeled as such.  Instead it has no label as the other boxes do, but it does include  what looks like 110. I have searched the internet and only found one German site which states that since Bosch was the only supplier of wipers that box was left unlabeled and instead Mercedes used that box for additional option codes. That same website indicated that (110.) referred to MB-LEDER TWIN which my research leads me to believe means twin leather where the seats were real leather and the rest was MB Tex.  I have not been able to find option code 110 on any other lists. Is anyone able to confirm or contradict that information?
John Micciche
'66 230sl 5-speed
'95 Ferrari F355 spider
'72 Jaguar E-Type roadster
'08 Dodge Viper convertible
'55 MG TF 1500 (sold)
'27 Cadillac LaSalle roadster (sold)
Re: option code Ho. MB-LEDER TWIN
« Reply #1 on: January 21, 2022, 16:27:32 »
Most interesting. I have a copy of the options list the German group put together some years ago, and it has a listing for 000 - steuerungs code fuer die fahrzeugproduktion translated to control code for vehicle production.
The first code after that is 200 for antifreeze.
Can you post a scan of the portion of the data card you are asking about?
john123
« Reply #2 on: January 24, 2022, 00:40:36 »
I can't get the picture to attach
John Micciche
'66 230sl 5-speed
« Reply #3 on: January 24, 2022, 11:09:47 »
Reduce its size. What extension does the file have?
Otherwise mail it to editor@sl113.org
john123
« Reply #4 on: January 24, 2022, 15:36:26 »
When I look again it looks like a capital H as in box #20 and a small number 0 as in the box above. I have no clue as to what that could mean.
I still can't get the image (4x6 jpg) to load.
Looks like this "Ho." in box #22
John Micciche
'66 230sl 5-speed
john123
« Reply #5 on: January 24, 2022, 15:37:26 »
I guess the image did load. I didn't show in preview.
John Micciche
'66 230sl 5-speed
« Reply #6 on: January 24, 2022, 16:34:41 »
Curious myself - battery brand?
Would be good to see the full card probably... does not look exactly like one of the versions we have in Tech Manual... Also the back side, as fields are sometimes explained on the back side.
john123
« Reply #7 on: January 24, 2022, 18:59:08 »
Thanks for your reply. The card I have is a copy supplied by the dealer when I purchased the car.  I do not have a copy of the back side.
I was thinking of ordering a copy of the card from Mercedes. Would they provide the back side as well? My understanding is that they send poor quality prints of data cards on film, which is probably what I have. I think it's probably worth the $150 to get one from Mercedes. I think I will do that, and send you a copy as soon as I get it.
thanks again.  But I'm not anxious to put out a copy of my data card for the world to see.
John Micciche
'66 230sl 5-speed
« Reply #8 on: January 24, 2022, 19:53:19 »
What you received from the dealer is all you get from Mercedes.
Of course, as you wish, just curious why - if you cover key codes.
Anyway, I thought it might have been battery brand, "Ho." for Hoppecke, but it is a wild guess. You would need to look and say if there is another field for battery brand and if it is filled. If there is - then it is not "Ho.for Hoppecke in field 22.
« Last Edit: January 24, 2022, 19:58:37 by Pawel66 »
alpina
    • MBDatacards
« Reply #9 on: January 25, 2022, 10:34:35 »
Hi John, I recreate full sets of data cards from the poor photocopy the Mercedes provide. I have recreated hundreds of data cards
and I can say for sure that there are many different styles of data card, far more than are shown in the Tech Manual. The 230SL alone
went through about 6 different styles. Slight changes where made to the size of boxes and the box number referencing.
Box 22 Scheibenwischer was either left blank or filled in with “Bosch”
Box 22  labelled Scheibenwischer no longer appears from Mid-1966. The box is just  #22 and is larger in size. From 1967 there is no box #22
just an empty box. It is in this empty box that a vast variety of letters have been printed for example ST, K, R, H, P, Stp, F, c, 2, S, g, Ho,
D, Sch, J, Q, es, m, n.
Unfortunatly  I do not know what these letters relate to. On the 280SL data card these letters would appear at the end of box #19 (Tires)
Your data card simply shows “Ho.“ in the empty box.
Box #20 shows the Tire manufacturer, in your case Phönix
Best regards DM.
« Reply #10 on: January 25, 2022, 12:35:12 »
I changed the topic of all the messages from 110 to Ho. so that it is easier to find in future searches...
john123
« Reply #11 on: January 25, 2022, 16:16:27 »
On my card box #9 is labeled Batterie, and it says Varta
John Micciche
'66 230sl 5-speed
john123
« Reply #12 on: January 25, 2022, 16:23:43 »
So I guess no way to get copy of back of card?
John Micciche
'66 230sl 5-speed
« Reply #13 on: January 25, 2022, 16:41:04 »
Please ask alpinaltd. He is the best equipped to find the back side to your data card and re-create the entire datacard set in the original formats for you to print. A lot of us requested his services, which are brilliant.
Ok, if you have another field dedicated to battery and it says Varta - my theory does not hold, I am afraid.
MikeSimon
  • USA, OH, North Royalton
« Reply #14 on: January 25, 2022, 16:56:23 »
I am by no means an expert like some others here, but here is a copy of the back of my data card - 1971 280SL Euro
It shows listings for fields 20-23 that do not appear on the front. Box 22 relates to owner info and is the residence.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #15 on: January 25, 2022, 17:33:55 »
Mike, mine has similar back side (1970 Euro), but then we do not have filed 22 on the front side, I think (front enclosed).
MikeSimon
« Reply #16 on: January 26, 2022, 13:59:44 »
Yes, Pawel, as I said, fields 20-23 do not appear on the front.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #17 on: January 26, 2022, 17:02:38 »
Mike, yes, sorry, wanted to refer to front and show it.
john123
« Reply #18 on: February 06, 2022, 20:01:01 »
Thanks for all of your thoughts.  This site is a fantastic resource.
John Micciche
'66 230sl 5-speed
