Author Topic: Clamp steering column lost  (Read 2875 times)
EeVeeWee
« on: January 15, 2022, 16:33:00 »
Two years ago I brought many parts to a company which did yellow passivating.
I made pictures from all the parts before I brought them and afterwards, but didn't check good enough.
Unfortunately now I realise I miss the clamp from the steering column.  :(
It can't be bought at SLS or Niemöller.
Does anybody have the dimensions from it so I can make it myself?
Thank you in advance.
Again something else.
Kevkeller
  • USA, HI, Honolulu
Re: Clamp steering column lost
« Reply #1 on: January 20, 2022, 14:19:55 »
Can you use a coat hangar to approximate the length and fit it?
1970 280 SL
EeVeeWee
« Reply #2 on: January 20, 2022, 16:15:26 »
I will make something myself indeed, I didn't get the dimensions (yet).
gordon
  • United Kingdom, England, Burntwood
« Reply #3 on: January 20, 2022, 19:50:22 »
The strap is 30 mm wide, 178 mm long to the heads of the bolts, which are 8 mm  X 70 mm long
EeVeeWee
« Reply #4 on: January 20, 2022, 20:49:20 »
Thank you!
I saw that one bolt is longer than the other, but that makes sense when you see the mounting holes in the dashboard.
