Author Topic: Bundt rims or not .  (Read 14661 times)
Benz280
  • USA, NJ, Jersey City
Bundt rims or not .
« on: November 14, 2021, 18:58:06 »
I know their has been much talk about bundts . Depending on your perspective, to some they look great, to others hubcaps are preferred.
Other than the look, is their any noticeable performance benefit given the lighter weight ?
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
MikeSimon
  • USA, OH, North Royalton
Re: Bundt rims or not .
« Reply #1 on: November 14, 2021, 19:21:13 »
Any alloy wheel has an advantage over steel wheels due to less unsprung weight. I am not sure, however, if it makes sense to talk "performance" in a W113 ?!?
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #2 on: November 14, 2021, 19:28:07 »
I really do not think there is anything performance related that would be noticeable. It is pure question of taste (I like them). And the usual practicalities that we all know from daily drivers corrected by higher than nowadays tire profile (thank God). These would be:
1. More weight needed to balance (as you do not apply them on the outer rim)
2. Careful with curbs
3. Careful on bad roads
« Reply #3 on: November 15, 2021, 16:40:46 »
Not a performance disadvantage, but after having them on a 107, they are a PITA to keep clean.
zak
« Reply #4 on: November 17, 2021, 19:23:12 »
I think the bundt wheels look good on a 123, but not much else.
They are fussy looking ( in my opinion ) and hard to keep clean.
In fact, when the tires on my 1983 - 107 aged out I swapped the factory14" bundts for 15 " - 16 hole " 560SL " type mag rims.
The 15's have a cleaner look to me and easier to keep clean.
Just my opinion.
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
MikeSimon
« Reply #5 on: November 17, 2021, 19:47:15 »
I really cannot agree with the "hard to keep clean" argument. I have had all kinds of alloy wheels on different cars and never had an issue. Not even with the BBS "Honeycomb" wheels. A proper spray-on wheel cleaner and a little higher pressure from a hose (not a pressure washer) is all it takes. Maybe a little agitation with a small brush.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
teahead
  • USA, WA, Des Moines
  • aka "Rob"
« Reply #6 on: November 18, 2021, 02:35:29 »
you can get the aluminum "steelies".
Either 14x5.5" or the rarer 14x6" ones.
lreppond
  • USA, CA, San Leandro
« Reply #7 on: November 18, 2021, 03:43:22 »
I doubt there’s an objectively correct answer here.  It solely depends on the owner’s personal taste.  I’ve seen some cars that look outstanding  with bundts.  My personal leaning is for hubcaps w/white walls.  So what I did is go with aluminum steelies and use my hubcaps & whitewalls.  If the unsprung weight really makes a difference in handling, I can say definitively it’s not perceptible.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
zak
« Reply #8 on: November 22, 2021, 20:15:51 »
That is interesting, Len. You maybe lightened the unsprung weight of your car by 100 lbs and felt no perceptible handling improvement.
Yet in reading numerous articles and posts it seemed that reducing the unsprung weight of the car was a positive improvement.
Maybe the benefit is felt in more of a performance car , as Mike Simon commented ?
The rims and tires make up all of the unsprung weight on the car, correct ?
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
dirkbalter
  • USA, CA, Corona
« Reply #9 on: November 22, 2021, 20:39:59 »
What about calipers, brake disks, other suspension components……
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
teahead
  • aka "Rob"
« Reply #10 on: November 22, 2021, 20:44:17 »
I think Bundt wheels are kinda...ugly.
Unless the Pagoda CAME with Bundts, why put them on?
If you must do something different than hubcaps, I'd rather get some BBS RS wheels:
MikeSimon
« Reply #11 on: November 22, 2021, 21:00:23 »
jz
Plus hubs, brake rotors/drums, calipers, lower suspension arm, rear axle, etc. Everything that is connected below the springs and adds to the load forcing the springs up, thus "unsprung"
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
scoot
  • USA, CA, Altadena
« Reply #12 on: November 22, 2021, 23:46:22 »
I'll disagree with others.  I think reducing the unsprung weight, particularly in front, makes a difference.  I have had the aluminum steelies on two of my cars (a 250C and a 300TD) and the place I would notice it is going around curves on roads that were in poor condition with patches and holes.  I noticed it a lot there.  It isn't going to turn your car into a rocket though.
Scott Allen
'67 250 SL (early)
Altadena, California
kampala
  • USA, CA, Hermosa Beach
« Reply #13 on: November 23, 2021, 02:46:22 »
I would agree with scoot.
I put aluminum steelies ( look like regular steel) with regular hubcaps on the 280 and I say there is a nice noticeable difference.  The car is more nimble and just feels lighter.  That’s the way I can describe it.  Agree that potholes and such are a little lighter hitting.
The 250 still has the steel wheels and the difference is clear.  I would put the aluminum steelies on the 250 but I like the dig dish hub caps and don’t want to put the later hub caps that the steelies work better with.
250sl - later - manual
280sl - 1971 - Auto - LSD
« Reply #14 on: November 23, 2021, 11:32:37 »
Was chatting about this in Austria. After discussion, I think I concluded I’d go 15” bundts but not 14s
Still prefer the hubcaps though so have the ally-steelies. Oh  but for those in a 15 (not that I could afford the hubcaps)
specracer
  • USA, MA, Duxbury
« Reply #15 on: November 23, 2021, 12:32:18 »
Rotational mass is every bit as important as unsprung weight. Zero doubt the overall feel of the car will be different with aluminum wheels (assuming they really weigh less than a stock steel).
I personally would NEVER stray from a stock look with hubcaps.
zak
« Reply #16 on: December 01, 2021, 22:01:50 »
Specracer, could you explain rotational mass and why it is important pls. This untechnical guy would like to understand.
It also appears that there is a lot of unsprung weight on our cars based on the unsprung list that Mike Simon compiled. It seems like it is more than just a couple of  hundred pounds in our 2900 lb cars .
A few months back I almost bought a 123 Euro 300D that had 15 inch wheels and hubcaps and even underbody protection. My plan was to swap the 15s onto my pagoda and give the 123 the 14 inch wheels. But the car turned out to be a rust bucket so I passed.
thanks,
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
specracer
  • USA, MA, Duxbury
« Reply #17 on: December 02, 2021, 02:21:55 »
I am NOT an engineer. So with that let me attempt... Unsprung weight is just that, its the wheels, spindles, brake assembly control arms etc. Yes this is important. Now rotational mass focuses more specifically on just the mass that is rotating. The rotor, wheel, hardware etc. Think of a bicycle / motorcycle, and how the wheels keep your balance. The heavier the wheels are, the harder the handle bars are to turn the cycle (changing the mass' direction). This mass has to also change direction, with bumps, and even makes a difference in acceleration and breaking.
« Reply #18 on: December 02, 2021, 11:14:10 »
As specracer says, it's about gyroscopic effect.
If you've ever fitted skinny tyres in place of fat ones with no other changes you'll notice how much lighter in handling the car feels.
As for unsprung weight:
The springs and shocks have to control linear movement of all of the components listed previously.
The lighter those components are (wheels) the quicker the springs and shocks will be able to control the linear movement.
Dynamically: as the tyre hits a bump it will be projected away from the road surface thus reducing grip. The faster it can be forced back on to the road the quicker the grip will be restored.
Obviously there are other benefits to weight loss but I'm sure a lot of us could do with that!
« Last Edit: December 02, 2021, 14:07:40 by stickandrudderman »
mnahon
  • Canada, QC, Montreal
« Reply #19 on: December 02, 2021, 12:29:57 »
I'd also say the aluminum steelies (or other lightweight wheels) offer an advantage in driving feel. kampala's and scoot's descriptions say it well. Their biggest advantage is over lousy roads, which we have many of here. Secondarily in more agressive driving where the car feels a bit more nimble. I've had aluminum steelies on for a few years and would not go back to the steel wheels.
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
UJJ
  • USA, CA, Grass Valley
« Reply #20 on: December 02, 2021, 15:13:10 »
I installed 15" Bundt wheels 4 years ago. And yes, quite a bit of performance increase, especially cornering. I changed back to the originals with hub caps this summer, but for only one day.
I do like the look, but a lot of sluggish feeling. I am back to the 15" Bundt and I am much happier driving my SL.
Greetings, Urban
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
« Reply #21 on: December 03, 2021, 01:22:35 »
Back in the day most cars of all makes had wheel covers or hub caps from the factory. Aluminum alloy wheels were an optional up-grade. I remember when the later Pagoda cars were offered with the optional Bundt wheels. They were an exciting "sporty looking" upgrade at the time. I still like the look of the Bundt alloys on the Pagoda  (in the sporting sense). These days many cars come standard with aluminum wheels and aluminum wheels are less remarkable to most people. The full wheel covers imply a more finished and sophisticated design. The Bundts are a sportier look. I like the idea of having a set of both! If so don't forget the alloy wheels require a longer lug bolt!
teahead
  • aka "Rob"
« Reply #22 on: December 03, 2021, 21:40:24 »
I only care for the 3-piece versions, which I don't think are made anymore:
« Reply #23 on: December 03, 2021, 22:16:21 »
I have a set of four 15'' wheel covers. I think they were once on a 600 in case someone is looking for something like that.
« Last Edit: December 04, 2021, 03:27:53 by Benz Dr. »
« Reply #24 on: December 03, 2021, 23:52:23 »
Three piece versions? Definitely not OEM Mercedes.
