Author Topic: What is this?  (Read 3005 times)
edwardburak@erols.com
  • USA, VA, Marshall
What is this?
« on: September 20, 2021, 19:12:52 »
1969 280sl usa version
What is this at the top of my block?
Does something connect to it?
thanks
Re: What is this?
« Reply #1 on: September 20, 2021, 19:16:02 »
Is it where the rev counter shaft connects? Do not laugh at me.
Nicolas Aristodemou
  • Cyprus, Lefkosia, NICOSIA
  • 280SL Auto 1970 W113, 380SL Auto 1982 R107
Re: What is this?
« Reply #2 on: September 20, 2021, 19:34:04 »
That’s right Powell, rev counter connection
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
  • USA, VA, Marshall
Re: What is this?
« Reply #3 on: September 20, 2021, 19:40:40 »
Rev counter? So the tachometer?
Re: What is this?
« Reply #4 on: September 20, 2021, 19:52:14 »
Yes, the tachometer - I assume yours does not work? Unless it was somehow converted to electronic ...
  • USA, VA, Marshall
Re: What is this?
« Reply #5 on: September 20, 2021, 19:54:45 »
I am putting my car back together, the tachometer is not yet installed. it will be cable driven
  Do you know the part number for the tachometer cable?
Re: What is this?
« Reply #6 on: September 20, 2021, 20:05:04 »
A 113 542 07 07
It is 1300mm. NLA at Mercedes, yo need to find it elsewhere. SLS would have it, so would Niemoeller probably, but you are the US, perhaps better to look for it at Authentic Classics or Bud's Benz.
« Last Edit: September 20, 2021, 20:51:59 by Pawel66 »
  • USA, VA, Marshall
Re: What is this?
« Reply #7 on: September 20, 2021, 20:08:02 »
got it, thanks
Re: What is this?
« Reply #8 on: September 20, 2021, 21:43:34 »
Only slightly related to this thread. It is not uncommon for the rev counter insert in the block to leak oil. Many years ago, the fellows here and I chased down why mine had a bit oil seeping out. Never really went all the way away. If I can find the thread I will "tach" it on here. (see what I did there?)
See attached: Was it really that long ago! And so many great names there. Naj was the best. Viewed 13185 times -- so its worth sharing...
https://www.sl113.org/forums/index.php?topic=3952.0;all
« Last Edit: September 20, 2021, 22:00:02 by J. Huber »
GM
  • USA, CO, Boulder
Re: What is this?
« Reply #9 on: September 20, 2021, 22:30:40 »
Edward,
In case you didn't know, from interactions with this forum you'll find that Pawel has near instantaneous recall on every Pagoda part number 🤣 ;)
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
  • USA, VA, Marshall
Re: What is this?
« Reply #10 on: September 20, 2021, 23:49:42 »
Yeah it's great, I'll look at that side thread
