Author Topic: Brass Springy Things  (Read 9645 times)
« on: May 02, 2005, 17:45:27 »
Nothing to report here other then we have a new thread for discussion of brass springy things. :D   Hereinafter referred to as BST's. (Registered Trademark)
« Last Edit: May 03, 2005, 07:24:53 by mdsalemi »
Re: Brass Springy Things
« Reply #1 on: May 02, 2005, 17:51:09 »
I stand corrected on this matter. I thought this part was purely a US-spec feature, but Rodd's Italian 230 SL has it.
« Reply #2 on: May 02, 2005, 18:01:39 »
My car lacks the BST.  I'll have to look over my data card and see if I have the code for the radio.
« Reply #3 on: May 02, 2005, 18:30:00 »
No BST. Netherlands delivery. No radio on DCard.
« Reply #4 on: May 02, 2005, 20:33:20 »
I've got a radio code on the DC (data card).  My BST is very tarnished, didn't even know it was B!  My FST (Funnel Shaped Thing) is intact.  Any other owner-created acronyms?
« Reply #5 on: May 02, 2005, 21:43:04 »
Someone should post a pic of the BST so others will know what we're talking about. :D
« Reply #6 on: May 03, 2005, 05:53:29 »
The part number of the elusive BST too please
seems like a new database is in order, maybe a study of all owners models, years, delivery, BST  yes/no
Rodd I thought it was a FSV(vent)T, either way a totally necessary part of every Pagoda.
« Reply #7 on: May 03, 2005, 07:26:26 »
I can't tell anyone who has it or why, but logic tells me that static is static, whether you are here in the USA or in Europe or Australia.  Radio supression too, knows know international boundaries.
« Reply #8 on: May 03, 2005, 08:16:10 »
Here's mine:
Download Attachment: P1010094.jpg
44.4 KB
« Reply #9 on: May 03, 2005, 09:38:58 »
Alright, let's take this discussion up a notch.  My 1966 230SL did not come with a factory installed radio and does not have the BST.  Rather, the selling dealer installed a Blaupunkt AM-FM mono unit and the correct front fender mounted manual antenna prior to delivery to the original owner.  This radio is still in the car and clearly suffers from a lack of suppression, both from the ignition and from the alternator.  There is both a high pitched whine and an ignition popping, each of which is r.p.m. related.  What should I be looking for, in addition to the BST, that the dealer probably didn't include in the installation all those many years ago?
« Reply #10 on: May 03, 2005, 14:31:16 »
There is no BST on my 250SL, and it does not have a radio. Also the FSVT is not on all 113 cars. When the change was made to the new vent tank (inside the left fender) the vapor vent was routed back to the engine. Again, no reference books with me, so I do not know the change point.
« Reply #11 on: May 03, 2005, 14:38:35 »
Gents--and others pining for BST's...
If you can't find one you can easily make one out of --spring brass!  Where do you get this?
www.smallparts.com
« Reply #12 on: May 03, 2005, 22:20:07 »
Hello Mike H,
The alternators on the radio equiped cars had a little square black supression device mounted on the back of the alternator. Also the original ignition wire sets had resistors on the spark plug wires at the spark plugs and the distributor.
« Last Edit: May 03, 2005, 22:20:51 by ja17 »
Vince Canepa
« Reply #13 on: May 04, 2005, 06:02:58 »
I think all the parts Joe is referring to were part of a Radio Suppression Kit.  I remember seeing a code for this.  The hood contact (BST) was probably part of this kit.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
« Reply #14 on: May 04, 2005, 06:18:56 »
Option code 533 is "interference suppresion less radio." Does anyone have this on their data card?
« Reply #15 on: May 04, 2005, 10:45:12 »
No 533 on my data card, which probably confirms the lack of BST and other suppression gear on my car.  Any thoughts on what the M-B part numbers for the missing alternator suppressor and suppression ignition wires might be?  Do I recall correctly reading on one of these forums that the use of resistor plugs is not recommended?
Vince Canepa
« Reply #16 on: May 04, 2005, 12:08:00 »
I checked and the data card for my car shows #533.  US version car sold by Stahl Motor Company in Monterey, Ca who fitted the Blaupunkt radio.  And my car has the suppression contact.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« Reply #17 on: May 04, 2005, 17:39:28 »
I have the 533 on my Data Card.  The dealer installed a Blaupunkt AM-FM-Short Wave radio with a power antenna.  Still works even if, sadly, the BBC hasn't broadcast SW for years.
'68 280SL 4-spd Coupe
« Reply #18 on: May 05, 2005, 05:34:28 »
The BBB 230SL, has job 82-20 for radio suppression.
It lists the suppressors needed throughout the electrical system.
Can I post a 600Kb PDF file on here?
« Reply #19 on: May 05, 2005, 08:24:40 »
Thanks, Bob!  Now all I need is to get my hands on a copy of the ever elusive BBB!
I took this shot of the back of my alternator.  Can anyone familiar with the noise suppression equipment tell me if it exists here?
Download Attachment: Alternator.jpg
43.26 KB
Tom230sl
« Reply #20 on: May 05, 2005, 15:12:06 »
I was told that the item highlighted was for radio noise surpression.  Hope this helps.
Download Attachment: P1160037.JPG
59.24 KB
« Reply #21 on: May 09, 2005, 05:01:14 »
Mike,
The thin Brown wire that is seen on the RHS + terminal looks to be going to the suppressor/condensor. (They are the same type of thing as on the distributor but they are treated separately)
It will only have one wire and will earth through its case to the body of the alternator.
