Author Topic: Funny "topcover" on my transmission box  (Read 3451 times)
BartSt
« on: July 10, 2021, 13:58:15 »
All,
"It fits but it doesn't ..."
I just spend the morning cleaning my transmission and I noticed that the top doesn't seem original ...
Pls have a look at the photo.
Who can explain what is going on?
Thanks (again)
Bart
BartSt
Re: Funny "topcover" on my transmission box
« Reply #1 on: July 10, 2021, 20:29:41 »
Nobody ... ?
That would be the first time ...
Leester
  • USA, VA, Lorton
« Reply #2 on: July 11, 2021, 00:10:45 »
Looks like mine.  Bear in mind that there are two different top covers, one for the top loader (yours and mine) and a different one for the side shifter that came with cars that had column shift. Since I don't have a side shifter I don't know if the profile of the top cover is different. I don't think you have a problem, at least with the top cover appearing to not fit.
Lee Backus
1963 220SE Cabriolet
« Reply #3 on: July 11, 2021, 05:04:53 »
It looks like any other top loader transmission that I've seen. Why do you think something's wrong?
BartSt
« Reply #4 on: July 11, 2021, 06:42:36 »
Because the hole on the corner doesn't make sense.
Why not cover the entire edge?
Bart
WRe
« Reply #5 on: July 11, 2021, 08:04:58 »
at the same time it looks strange but it should be okay.
...WRe
ejboyd5
  • Southold, NY
« Reply #6 on: July 11, 2021, 18:17:02 »
Note same "mismatch" on 300 SL transmission. Case was designed to accept several different covers depending upon application.
BartSt
« Reply #7 on: July 11, 2021, 19:08:24 »
Ok, thanks. Learned again something interesting this week.
Those funny Germans ...
« Reply #8 on: July 14, 2021, 10:36:06 »
I think what you are looking at is a dowel pin hole. In order to machine the raw casting correctly that would have been where the case was located on the fixture for final machining.
Raw casting
Face the top of the case and drill dowel holes.
Flip case and install on fixture.
Face front and back and bore bearing bosses.
Once the top is milled and the dowel holes are drilled every other operation keys off that height and location.
« Last Edit: July 21, 2021, 19:38:15 by Shvegel »
