Author Topic: Wiring harness  (Read 5710 times)
BOTIGER1970
  • USA, NC, Mooresville
Wiring harness
« on: June 22, 2021, 23:25:05 »
I am seeking advice about wiring harnesses.  I am in the process of doing a complete restoration on my 1970 280SL.  I am fairly new to the Mercedes world and still learning a lot.  I have been restoring Corvettes for the last 30 years and have found the experiences in restoring Corvettes much different then restoring Mercedes.  There seems to be more information and judging manuals available for Corvettes in the effort to restore.  My question is in restoring wiring harnesses; what is the best process in either restoring or replacing wiring harnesses.  No matter the restoration, I believe in making sure the wiring harnesses are either restored or replaced.  I want to make sure if I replace the harness, that the replacement harness is as close to original as possible.  Is there a good replacement available.  I have a long way to go on this restoration, so this won't be my last question.  Any help appreciated.
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
Re: Wiring harness
« Reply #1 on: June 22, 2021, 23:39:57 »
You might want to have a look at this thread:
https://www.sl113.org/forums/index.php?topic=33079
Note: I have no connection or experience with this vendor.
           -David
-David Pease
Re: Wiring harness
« Reply #2 on: June 23, 2021, 06:51:23 »
Check with lpeterssen in this group.
dirkbalter
  • USA, CA, Corona
Re: Wiring harness
« Reply #3 on: June 23, 2021, 14:44:28 »
If above doesn't work out, I am installing a wiring harness that came from Rode Island wiring.
https://www.riwire.com/
All wires and colors matched perfect. No connecters though. You will have to use your connectors and pins.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
