Author Topic: Bonnet badge  (Read 5774 times)
RAY
Bonnet badge
« on: June 07, 2021, 18:02:38 »
Is it possible to remove the bonnet badge without removing the bonnet ? I know the back of the badge has a threaded stud and a locating pin on it but looking under the bonnet it appears these disappear into a box section ?
Re: Bonnet badge
« Reply #1 on: June 07, 2021, 18:27:41 »
Ray,
When you open de bonnet, you can reach the little nut which is holding the badge.
Re: Bonnet badge
« Reply #2 on: June 08, 2021, 13:45:51 »
or if you have small hands can go through the grille star center and reach up to the small 7mm nut inside with a ratchet on an extension bar.
Walter
RAY
Re: Bonnet badge
« Reply #3 on: June 09, 2021, 17:41:10 »
Thank you guys.
Merc_Girl
  • United Kingdom, England, Godalming
Re: Bonnet badge
« Reply #4 on: June 09, 2021, 17:59:49 »
Walter
Alternatively use a grandchild, they don’t  even to be yours!?!.🤣
230SL
RAY
Re: Bonnet badge
« Reply #5 on: June 10, 2021, 16:49:29 »
Now thats an idea ! I have couple knocking around.
RAY
Re: Bonnet badge
« Reply #6 on: June 13, 2021, 16:58:13 »
I had a closer look this weekend through the grill star and cant see any nut visable just this box section. See pic.
Is mine different to others ?
Re: Bonnet badge
« Reply #7 on: June 13, 2021, 17:31:57 »
Hi Ray,
Some picture:
•   First open a bit the hood
•   Then go via the grill star
•   And you will find the nut
RAY
Re: Bonnet badge
« Reply #8 on: June 14, 2021, 17:27:54 »
Thanks Peter,
I am a bit baffled, looking at your picture it would appear that the bolt is in front of the box section ?
My photo is taken with the bonnet shut and if you expand the picture you can see clearly behind and in front of the box section and their appears to be nothing.
I will do as you have done and open the bonnet and have a look next time i,m at the garage and update situation.
Re: Bonnet badge
« Reply #9 on: June 14, 2021, 21:51:15 »
I think your screw is about 1cm outside of the picture's top frame, a bit to the left...
MikeSimon
  • USA, OH, North Royalton
Re: Bonnet badge
« Reply #10 on: June 15, 2021, 19:37:01 »
My hood is off the car and I can take an easy picture. The "bolt" and nut come out of the hood in front of the box section. Please note that I have a "special custom" nut and bolt coated with "rust-like" appearance, as proper for a Vintage car.
I would guess that someone used a "stick-on" badge on your car during/after a repaint process. Also, the picture in your original post does not show the front center of the box section...
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Re: Bonnet badge
« Reply #11 on: June 15, 2021, 21:13:10 »
Someone must have coated ca 70% of one of my cars with "rust-like-appearance" coating...
MikeSimon
Re: Bonnet badge
« Reply #12 on: June 16, 2021, 12:28:26 »
Very expensive and sought-after option, Pawel! Cherish it! 8)
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
Re: Bonnet badge
« Reply #13 on: June 16, 2021, 13:36:54 »
As a fun little fact, at one of the PUBs in Blacklick, Ohio--probably 2011 or so, in walking around the myriad number of cars parked all around Joe Alexander's property, I happened to notice that there was a large number of cars w/o the "bonnet badge" or hood badge--enough to question at that time. Were they horrifically expensive, or unavailable? It was a bit curious as to why so many were missing...
RAY
Re: Bonnet badge
« Reply #14 on: June 16, 2021, 17:06:53 »
Hi all,
Tilted the bonnet and have found it, sort of. Just the bolt hole though, no bolt, for some reason it must be stuck on.
Now have to figure a way of removing it without damaging the paintwork  :-\
Norm
  • USA, TX, Wimberley
Re: Bonnet badge
« Reply #15 on: June 16, 2021, 17:29:16 »
I had to remove some badging from my motorcycle a while back.  Fishing line hooked under the badge and a "sawing" motion cut through the adhesive pad holding it on.  Worked like a charm! :)
Good luck.....
Norm
Norm
1966 230SL 162H Blue-Grey
1994 Acura NSX Formula Red
2024 Acura RDX A-Spec, White Pearl
2016 Mercedes S63 AMG Coupe Obsidian Black
2011 Harley Davidson Super Glide Light / Dark Root Beer
Re: Bonnet badge
« Reply #16 on: June 16, 2021, 20:47:38 »
The hood badge is expensive. Some people use a 450SL badge and just glue it on.
The 190SL and 113 use the same badge except the threaded pin is opposite position on the 190.
1988 560SEC
Re: Bonnet badge
« Reply #17 on: June 16, 2021, 20:49:15 »
Warming up with an air blower may work, if the fishing line does not.
Merc_Girl
Re: Bonnet badge
« Reply #18 on: June 16, 2021, 21:28:31 »
I found fishing line the best, then some elbow grease to remove remaining glue.
Worked when I ‘de-badged’ my SLK 😁
Silly question, why are you wanting to remove.? 😉
230SL
MikeSimon
Re: Bonnet badge
« Reply #19 on: June 17, 2021, 23:56:15 »
Dental Floss works too. Have taken quite a number of glued emblems off painted surfaces with it.
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
RAY
Re: Bonnet badge
« Reply #20 on: June 18, 2021, 17:33:30 »
Thanks all for the fishing line and floss ideas I will give them a try.
I need to remove the existing one because its not a Pagoda badge, its from a newer model, all silvery in colour not like the cream star of the Pagoda badge and it anoys me. I had a Pagoda badge restored and would like to now fit that.
Merc_Girl
Re: Bonnet badge
« Reply #21 on: June 18, 2021, 22:52:21 »
Going to look at my badge now!
230SL
RAY
Re: Bonnet badge
« Reply #22 on: June 20, 2021, 20:06:44 »
Job done, the fishing line worked a treat, cheers Norm.
Merc_Girl
Re: Bonnet badge
« Reply #23 on: June 22, 2021, 09:32:49 »
VERY nice
Glad fishing line worked for you 😁
230SL
