with our official
Pagoda SL Group logo
from our official partner.
Photo Gallery
67 230sl
Topic: 67 230sl (Read 6049 times)
Bconley759
67 230sl
May 27, 2021, 12:04:49 »
Well pretty excited just put some color on the bottom of my car, was a lot of work just to get here. Planning on spraying undercoating in the fender wells that factory used, need some help.
dirkbalter
Full Member
Platinum
USA, CA, Corona
Re: 67 230sl
May 27, 2021, 15:08:18 »
I used U-pol Gravitex. I think it looks close to original and is paintable. I like it. If interested I can send you a better picture.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Bconley759
Re: 67 230sl
Reply #2 on:
May 27, 2021, 16:01:25 »
Yea definitely I need to get it done, can’t find an original description. The original undercoating was pretty bullet proof
Bconley759
Re: 67 230sl
Reply #3 on:
May 27, 2021, 16:06:31 »
I see the rough texture under your car what did you use
dirkbalter
Full Member
Platinum
USA, CA, Corona
Re: 67 230sl
Reply #4 on:
May 27, 2021, 17:09:14 »
Here are a couple of pics to give you an idea of the texture. I sprayed my whole underbody and any area I figured could use some. If you are after strictly original, you may want to check out:
https://motoringinvestments.com/
I am not sure if all cars had undercoating and if they were all spayed in the same fashion.
Other members used different undercoating. The U-pol was recommended and as you probably know, needs a special gun to spray. I sprayed the coating prior to paint. I also painted the underbody afterwards. I believe originally it was only slightly "over-sprayed". I will post some after paint pic tonight.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
dirkbalter
Full Member
Platinum
USA, CA, Corona
Re: 67 230sl
Reply #5 on:
May 28, 2021, 01:22:31 »
after paint
Last Edit: May 28, 2021, 01:30:29 by dirkbalter
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Photo Gallery
67 230sl
