Author Topic: 67 230sl  (Read 6047 times)
Bconley759
67 230sl
« on: May 27, 2021, 12:04:49 »
Well pretty excited just put some color on the bottom of my car, was a lot of work just to get here. Planning on spraying undercoating in the fender wells that factory used, need some help.
dirkbalter
  • USA, CA, Corona
Re: 67 230sl
« Reply #1 on: May 27, 2021, 15:08:18 »
I used U-pol Gravitex. I think it looks close to original and is paintable. I like it. If interested I can send you a better picture.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Bconley759
Re: 67 230sl
« Reply #2 on: May 27, 2021, 16:01:25 »
Yea definitely I need to get it done, can’t find an original description. The original undercoating was pretty bullet proof
Bconley759
Re: 67 230sl
« Reply #3 on: May 27, 2021, 16:06:31 »
I see the rough texture under your car what did you use
dirkbalter
  • USA, CA, Corona
Re: 67 230sl
« Reply #4 on: May 27, 2021, 17:09:14 »
Here are a couple of pics to give you an idea of the texture. I sprayed my whole underbody and any area I figured could use some. If you are after strictly original, you may want to check out:
https://motoringinvestments.com/
I am not sure if all cars had undercoating and if they were all spayed in the same fashion.
Other members used different undercoating. The U-pol was recommended and as you probably know, needs a special gun to spray. I sprayed the coating prior to paint. I also painted the underbody afterwards. I believe originally it was only slightly "over-sprayed". I will post some after paint pic tonight.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
dirkbalter
  • USA, CA, Corona
Re: 67 230sl
« Reply #5 on: May 28, 2021, 01:22:31 »
after paint
« Last Edit: May 28, 2021, 01:30:29 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
