Author Topic: Propshaft Flexi Joint  (Read 2500 times)
Klemmflyer
« on: March 31, 2021, 14:52:34 »
I had a catastrophic failure of the flexible coupling on my 4 speed 280 .. the flexible coupling flew apart at speed ... ouch ... I have managed to get all the parts to repair the damage including a new flexible coupling ... I noticed on the information regarding the flexible that it’s important that it’s fitted with the correct orientation .
My problem is that the new Flexi, although it’s the correct part has no indication of what the orientation should be , and is not like the moulding on the technical info on our forum ... I’ve attached a couple of photos of the coupling and I’m looking for some sage advice ! ... thanks in advance ... Jim
Klemmflyer
Re: Propshaft Flexi Joint
« Reply #1 on: March 31, 2021, 14:54:46 »
Sorry .. I’ve sent the same photo twice ...
« Reply #2 on: March 31, 2021, 15:17:56 »
I believe these are bi-directional but I was always taught in my MB training to fit couplings so that lettering was towards propshaft unless stated otherwise.
Klemmflyer
« Reply #3 on: March 31, 2021, 15:20:29 »
Thanks stranger ... long time etc .. stay safe ..
Klemmflyer
« Reply #4 on: March 31, 2021, 16:02:36 »
I just re-read the article on the flexdisc in the technical manual and noticed the paragraph on ‘ new style flex disc’ ... problem solved !
« Reply #5 on: March 31, 2021, 18:52:58 »
Yes the new flex discs are much more robust and are able to be installed in either direction.
