Please check out joining the
Emergency Contact List
for help during your travels!
Changing gears is a little hard
Topic: Changing gears is a little hard (Read 3333 times)
col320ce
Full Member
Gold
Australia, Victoria, Glen Iris
December 25, 2020, 08:02:55 »
The 4 speed manual transmission on my 230sl is a little hard to get into 2nd gear. Both changing up or down. When I say hard it's more slow to let me engage the gear. I found a post where Joe A said the synchro is normally OK which is what I assumed was the problem. I'm pulling the engine out to paint the car and I am unsure whether I need to do anything with the tranny. Is this a setup issue potentially? Thoughts on whether I diy the transmission while it's out?
BTW I gave Glenns tune up guide on order.
Last Edit: December 27, 2020, 06:21:52 by col320ce
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
wayne R
Re: Changing gears is a little hard
December 25, 2020, 14:44:14 »
Hi Col---Wayne here Queensland Australia---ill PM you with my phone number,
then i can help you alot over the phone,with how to check , adjust,and test your tranny
,as its easy to contact by phone same country--regards .
Full Member
Platinum
USA, OH, Blacklick
Reply #2 on:
December 25, 2020, 14:52:52 »
Make sure the transmission modulator linkage works correctly and freely while you have the transmission out! You can energize the three position solenoid while it is out and observe its function.
col320ce
Full Member
Gold
Reply #3 on:
December 25, 2020, 20:43:23 »
Thanks Wayne and Joe
PM sent to you Wayne!
Col
1964 230SL
1965 250SE coupe
col320ce
Full Member
Gold
Reply #4 on:
December 27, 2020, 06:23:05 »
Sorry... It's a manual... I wrote auto originally (I've corrected it in the original post)
Col
1964 230SL
1965 250SE coupe
Vendor
Platinum
United Kingdom, England, Richmond
Reply #5 on:
December 27, 2020, 10:13:08 »
Be sure that you've got the correct (ATF) fluid in the box. If you put normal gear oil in it you'll get difficulty shifting.
Stick
www.colinferns.com
cfm65@me.com
Associate Member
Gold
Cape Town, South Africa
Reply #6 on:
December 27, 2020, 13:33:13 »
Hi Col,
Is the gear lever sloppy and loose? If so, this could also be the reason for not selecting the gear properly. There are a few nylon bushes in the linkage between the gearbox and the lever. The become brittle and disintegrate over time and are quite easily replaced.
Chris
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
Full Member
Platinum
USA, OH, Blacklick
Reply #7 on:
December 27, 2020, 14:13:28 »
Check the needle on your speedometer. If it moves down for an instant when you accelerate, then bounces up when you let off the gas, then it is probably a loose slotted nut on the out-put flange of the transmission.
col320ce
Full Member
Gold
Reply #8 on:
December 27, 2020, 23:13:50 »
Thanks everyone... Chaging the oil has made a significant improvement! All gears now feel the same to get into.
I replaced all the nylon washers when I got the car as they were toast.
No needle jumping on acceleration/taking foot off accelerator.
There was a little ferrous material in the drained fluid... Is this normal? All of it is in the picture.
Col
1964 230SL
1965 250SE coupe
