Author Topic: Cylider Head Bolts - Do They Need Sealer  (Read 2238 times)
Kamihome@btcpc.com
  • USA, IL, Kildeer
« on: August 18, 2020, 22:45:56 »
Does anyone know if the block holes that receive the cylinder head bolts are dead ended, or do the cylinder head bolts needs sealer?  I have looked at BBB and did not find any specific information about this.
Thank you,
Kami Farahmandpour
'67 250SL
sandcrab59
  • USA, MA, Lunenburg
Re: Cylider Head Bolts - Do They Need Sealer
« Reply #1 on: August 19, 2020, 11:06:25 »
My experiences with rebuilding engines , No to any sealer.
I could be wrong with an SL engine.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
« Reply #2 on: August 19, 2020, 16:31:29 »
I believe all are blind holes.  I use a bit of oil on the threads and on the washers under the heads of the bolts.
Kamihome@btcpc.com
  • USA, IL, Kildeer
« Reply #3 on: August 20, 2020, 01:13:09 »
Thank you for your responses.
