Author Topic: 113 Rear Diff Split Boot  (Read 3636 times)
Benz280
  • USA, NJ, Jersey City
« on: August 05, 2020, 18:00:20 »
Having looked and read many comments from others that have performed this, the question comes up, does oil reside in the boot under normal circumstances ? And if their is oil in the boot, world that indicate a problem with the axle seal ?
Ill be doing working this weekend on this project .
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Re: 113 Rear Diff Split Boot
« Reply #1 on: August 05, 2020, 21:10:16 »
There should always be a certain amount of oil within the folds of the boot.
Benz280
« Reply #2 on: August 06, 2020, 13:56:29 »
Thanks Benz Dr. , just so Im clear, overtime then the boot will accumulate a reasonable amount of oil.
I mention because my exiting boot has a crack on-top and and I notice oil exits when driving, I suspect the spinning axle throws it up then exits.
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #3 on: August 06, 2020, 14:19:00 »
With the car flat on its wheels there should be oil in the axle to the plug on the rear of the axle.  Use a 14 mm hex wrench to remove the plug to check the oil level.  There is just enough room to slide under the car without jacking up the car...
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
Desertpagoda
  • USA, AZ, Tucson
« Reply #4 on: August 07, 2020, 00:10:35 »
Yes, there is oil in the boot
kb
Benz280
« Reply #5 on: August 07, 2020, 02:11:20 »
Thank you all , 113 owners are a great group.
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Benz280
« Reply #6 on: August 17, 2020, 21:51:15 »
Final question for the group, I see photos where the seam is at 9 o clock, others show 12 o clock.
I would think 12 o'clock would be best.
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #7 on: August 18, 2020, 13:12:23 »
The shape of the boot makes it so the seem should be to the rear at 9 o'clock.  It will not flex properly  in the other position.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2025 E53 AMG Sedan
Benz280
« Reply #8 on: August 19, 2020, 14:17:02 »
Boot is installed and came out great, as others have said, take your time and only use OEM parts.
Couple of pointers :
Make sure boot is thoroughly clean.
Pre crimp clips on workbench, but not tighten.
Use a gasket sealant, apply gently
Used std screw hose clamps.
I added additional clips using a thick wire .
Thank you all for your comments.
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
