Author Topic: Wanted: early window winder/crank for 230sl  (Read 5942 times)
Merc_Girl
  • United Kingdom, England, Godalming
« on: July 07, 2020, 08:16:14 »
Hi folks
I have discovered that my 230sl has two different designs of window winder/crank, with the passenger side having the latter design.
Does anyone happen to have any early version please
Thank you
Katie
230SL
scoot
  • USA, CA, Altadena
Re: Wanted: early window winder/crank for 230sl
« Reply #1 on: July 07, 2020, 15:01:13 »
There are three versions of window cranks:
1.  Early small knob, held in by a screw
2.  Middle, big knob, held in by screw
3.  Late, big knob, held in by a clip that is part of the crank insert pad (the upholstered colored thing)
You have a 230 SL so you should have the small knob version, the first one.  Are you saying that your window cranks don't both look like #1?    Pics attached.
Scott Allen
'67 250 SL (early)
Altadena, California
scoot
  • USA, CA, Altadena
« Reply #2 on: July 07, 2020, 15:02:09 »
I think what can happen is at some point your window regulator gets replaced and it gets replaced with the later style (that doesn't have a screw to hold in the crank, so your crank gets replaced with the later style also.  Is this what has happened with your car?
Scott Allen
'67 250 SL (early)
scoot
  • USA, CA, Altadena
« Reply #3 on: July 07, 2020, 16:11:34 »
Oh, and for what it's worth I have all types of window cranks...
Scott Allen
'67 250 SL (early)
« Reply #4 on: July 07, 2020, 17:20:52 »
Hello Scott,
great info; please add it to our technical manual. https://www.sl113.org/wiki/ChassisBody/Windows
Thanks.
« Reply #5 on: July 07, 2020, 17:40:34 »
Yup. That Scot guy sure has a good handle on things.
1988 560SEC
wjsvb ✝︎
  • USA, VA, Virginia Beach
« Reply #6 on: July 07, 2020, 18:04:24 »
Amen to that!  He's good on Becker radios too! The window handle guide should be in the Tech Manual!
jon
67 250SL early
81 280SL Euro 4spd
scoot
  • USA, CA, Altadena
« Reply #7 on: July 07, 2020, 18:21:09 »
OK, I'll put the window handle guide into the tech manual, along with samples of which types of crank insert fit for each one...   :-)   Scott
Scott Allen
'67 250 SL (early)
Merc_Girl
« Reply #8 on: July 07, 2020, 19:15:12 »
Hi chaps
Thanks for your replies.
So, the drivers door has the first style, which is the correct one, with a small knob.
The passenger has a different design, which is incorrect and the one I need to replace, if I can
Pictures attached
230SL
Merc_Girl
« Reply #9 on: July 07, 2020, 19:29:17 »
Once I’ve replaced the incorrect one I will have a #2 style window winder/crank handle available if someone needs one 😂
Also, I know I may be being a bit odd, but it seems ver ‘unGerman’, but the windows operate in different ways:
- drivers side the winder is turned clockwise to lower the window
- passenger side, if the winder is turned clockwise it raises the window!!!
Is this normal???
230SL
scoot
  • USA, CA, Altadena
« Reply #10 on: July 07, 2020, 19:34:05 »
I need a picture of the passenger side, without the crank insert installed.  Then I can tell you the answer.
Scott Allen
'67 250 SL (early)
Merc_Girl
« Reply #11 on: July 07, 2020, 20:34:18 »
So, this is the wrong design for the year, although it does appear to have a small knob?
230SL
scoot
  • USA, CA, Altadena
« Reply #12 on: July 07, 2020, 21:29:47 »
No, that is perfectly correct.  You said the passenger side doesn't match.  Attach pic of the passenger side that doesn't match.
Scott Allen
'67 250 SL (early)
« Reply #13 on: July 07, 2020, 22:51:56 »
Most Mercedes sedans of the era W110, W111, early W108 with manual windows also used the early style window crank.
scoot
  • USA, CA, Altadena
« Reply #14 on: July 07, 2020, 22:59:35 »
...which is why I have a nice box of them...  I used to do a lot of junkyarding...
Scott Allen
'67 250 SL (early)
Merc_Girl
« Reply #15 on: July 09, 2020, 21:49:58 »
With thanks to all my fine SL113 friends for all your helpful pointers.
Now sourced the item needed from one of our group members
Take care
Katie
230SL
