with our official
Pagoda SL Group logo
from our official partner.
Body, interior, paint, chrome, and cosmetic items
Differential restore question
Topic: Differential restore question (Read 4975 times)
230slhouston
Full Member
Senior
USA, TX, Houston
July 02, 2020, 17:16:42 »
Hi all,
I am about to restore my differential. Never had any issues with it but want to replace as much a possible.
I understand this is precision work. Can someone share with me bearings etc not to tinker with? I want to avoid having to adjust shims etc.
Maistran
Associate Member
Platinum
Canada, ON, Port Lambton
Re: Differential restore question
July 02, 2020, 17:57:14 »
Replace all of your rubber bushings, seals, axle bearings, and probably the bushings on the hinged shaft. I wouldn't get into the main carrier bearings or pinion bearings unless you have to.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
230slhouston
Full Member
Senior
USA, TX, Houston
Reply #2 on:
July 03, 2020, 14:34:32 »
Thanks Dan.
I don't want to be be too invasive. Question, Can I remove the the left side support tube to replace the gasket? I don't want to remove the crown wheel.
Thanks.
Full Member
Platinum
USA, OH, Blacklick
Reply #3 on:
July 04, 2020, 01:54:26 »
There is no gasket. Only sealer is used. Yes the left tube and axle assembly can be removed by itself.
230slhouston
Full Member
Senior
USA, TX, Houston
Reply #4 on:
July 04, 2020, 04:42:59 »
Thanks Joe.
Will share pics as I go. My homework tomorrow.
Maistran.
230slhouston
Full Member
Senior
USA, TX, Houston
Reply #5 on:
July 07, 2020, 00:23:27 »
One more question on the shaft bearings.
RH has a roller bearing. NieMoller has a part number 000-981-05-06. Is this the right part and is it only available from MB or is there aftermarket FAF/SKF. The FEBI kit looks like it only comes with a ball bearing.
https://www.autohausaz.com/pn/1113500068
Thanks.
Associate Member
Platinum
Reply #6 on:
July 07, 2020, 01:25:48 »
Go to a bearing supplier and order the number from your old bearing.
Everyone
does this; even me.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
230slhouston
Full Member
Senior
USA, TX, Houston
Reply #7 on:
July 07, 2020, 02:00:54 »
Thanks Dan. I will strip it of the shaft and get the number.
Maistran.
Associate Member
Platinum
Reply #8 on:
July 07, 2020, 14:56:13 »
If you don't have one of those wrenches for removing the axle nut, get one. You'll need it and they're not that much to buy.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
mbzse
Full Member
Platinum
Sweden, Stockholm, Stockholm
Reply #9 on:
July 07, 2020, 15:27:56 »
Tool
/Hans S
Associate Member
Platinum
Reply #10 on:
July 07, 2020, 16:19:24 »
That's a different style from the one I use but it should work just as good.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
230slhouston
Full Member
Senior
USA, TX, Houston
Reply #11 on:
July 07, 2020, 16:22:10 »
Anyone know where I can buy a wrench...or a pic of a home made one since it is single use for me.
Associate Member
Platinum
Reply #12 on:
July 07, 2020, 17:45:50 »
Authentic Classics have them.
1970 3.5 Coupe
1961 190SL
1981 300SD
2013 GMC Sierra
1965 230SL
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #13 on:
July 07, 2020, 17:46:45 »
Plenty of them around, just a question of size:
https://www.ebay.com/itm/Adjustable-Hook-Wrench-C-Spanner-19-51mm-Round-Head-Hand-Tool-for-Nuts-Bolts/132984797696?hash=item1ef682fa00:g:CmIAAOSwk4hchjr-
Associate Member
Platinum
USA, OH, Cleveland Heights
Reply #14 on:
July 11, 2020, 10:44:19 »
just as a heads up the axle shafts are 2 different lengths. make sure the odd (Angular Contact) bearing ends up on the right side shaft.
