Author Topic: Differential restore question  (Read 4965 times)
230slhouston
  • USA, TX, Houston
« on: July 02, 2020, 17:16:42 »
Hi all,
I am about to restore my differential. Never had any issues with it but want to replace as much a possible.
I understand this is precision work. Can someone share with me bearings etc not to tinker with? I want to avoid having to adjust shims etc.
Maistran
Re: Differential restore question
« Reply #1 on: July 02, 2020, 17:57:14 »
Replace all of your rubber bushings, seals, axle bearings, and probably the bushings on the hinged shaft. I wouldn't get into the main carrier bearings or pinion bearings unless you have to.
230slhouston
  • USA, TX, Houston
« Reply #2 on: July 03, 2020, 14:34:32 »
Thanks Dan.
I don't want to be be too invasive. Question, Can I remove the the left side support tube to replace the gasket? I don't want to remove the crown wheel.
Thanks.
« Reply #3 on: July 04, 2020, 01:54:26 »
There is no gasket. Only sealer is used. Yes the left tube and axle assembly can be removed by itself.
230slhouston
  • USA, TX, Houston
« Reply #4 on: July 04, 2020, 04:42:59 »
Thanks Joe.
Will share pics as I go. My homework tomorrow.
Maistran.
230slhouston
  • USA, TX, Houston
« Reply #5 on: July 07, 2020, 00:23:27 »
One more question on the shaft bearings.
RH has a roller bearing. NieMoller has a part number 000-981-05-06. Is this the right part and is it only available from MB or is there aftermarket FAF/SKF. The FEBI kit looks like it only comes with a ball bearing. https://www.autohausaz.com/pn/1113500068.
Thanks.
« Reply #6 on: July 07, 2020, 01:25:48 »
Go to a bearing supplier and order the number from your old bearing. Everyone does this; even me.
230slhouston
  • USA, TX, Houston
« Reply #7 on: July 07, 2020, 02:00:54 »
Thanks Dan. I will strip it of the shaft and get the number.
Maistran.
« Reply #8 on: July 07, 2020, 14:56:13 »
If you don't have one of those wrenches for removing the axle nut, get one. You'll need it and they're not that much to buy.
mbzse
« Reply #9 on: July 07, 2020, 15:27:56 »
Tool
/Hans S
« Reply #10 on: July 07, 2020, 16:19:24 »
That's a different style from the one I use but it should work just as good.
230slhouston
  • USA, TX, Houston
« Reply #11 on: July 07, 2020, 16:22:10 »
Anyone know where I can buy a wrench...or a pic of a home made one since it is single use for me.
« Reply #12 on: July 07, 2020, 17:45:50 »
Authentic Classics have them.
« Reply #14 on: July 11, 2020, 10:44:19 »
just as a heads up the axle shafts are 2 different lengths.  make sure the odd (Angular Contact) bearing ends up on the right side shaft.
