Please check out joining the
Emergency Contact List
for help during your travels!
Very Tight Rocker Arm/Valve Cover
Topic: Very Tight Rocker Arm/Valve Cover (Read 2215 times)
mistertj
Full Member
Senior
USA, FL, Satellite Beach
June 06, 2020, 22:32:12 »
It's always difficult and a task to remove the rocker arm / valve cover. It binds between the hood latch mechanism and fuel injector lines. Wondering if this is common or if my engine is too far back? Thoughts?
Vander
Full Member
Silver
USA, OH, Columbus
Re: Very Tight Rocker Arm/Valve Cover
June 06, 2020, 23:28:53 »
Sometimes this is a sign of a worn out transmission mount. You can position a floor jack where the transmission bolts to the motor and this will lift it in the rear to give you more clearance for the valve cover.
mistertj
Full Member
Senior
Reply #2 on:
June 07, 2020, 11:17:22 »
Thank you.
450sl
Full Member
Silver
Netherlands, Gelderland, zelhem
Reply #3 on:
June 07, 2020, 17:10:48 »
Mister, With frontwheels in the air You will find that there is enough space to remove the Rocker over.
Mark
