Author Topic: Very Tight Rocker Arm/Valve Cover  (Read 2213 times)
mistertj
  • USA, FL, Satellite Beach
« on: June 06, 2020, 22:32:12 »
It's always difficult and a task to remove the rocker arm / valve cover. It binds between the hood latch mechanism and fuel injector lines. Wondering if this is common or if my engine is too far back? Thoughts?
Vander
  • USA, OH, Columbus
Re: Very Tight Rocker Arm/Valve Cover
« Reply #1 on: June 06, 2020, 23:28:53 »
Sometimes this is a sign of a worn out transmission mount. You can position a floor jack where the transmission bolts to the motor and this will lift it in the rear to give you more clearance for the valve cover.
mistertj
« Reply #2 on: June 07, 2020, 11:17:22 »
Thank you.
450sl
« Reply #3 on: June 07, 2020, 17:10:48 »
Mister,  With frontwheels in the air You will find that there is enough space to remove the Rocker over.
Mark
