Author Topic: 230SL Chain Tensioner Part Number  (Read 2201 times)
mistertj
  • USA, FL, Satellite Beach
« on: May 05, 2020, 21:27:22 »
Does anyone have a good part number for the chain tensioner pad for a 230SL? The part numbers I have don't match anything. Thank you.
Re: 230SL Chain Tensioner Part Number
« Reply #1 on: May 05, 2020, 23:05:44 »
PN for 113042, M127.981 is A 180 050 07 16. NLA at MB the system says, but if you ask Classic Center, maybe it is possible to order. It was ca $200.
I am sure other Members will have options where to source it. I was just able to find LEMFÖRDER 17904 01.
mistertj
« Reply #2 on: May 05, 2020, 23:29:32 »
Maybe it'll be cheaper if I replace the timing chain. The plate still has surface left, it's just the two ridges that are worn off.
mbzse
« Reply #3 on: May 06, 2020, 07:05:37 »
Quote from: mistertj
The guide rail and the chain should never touch :-\
See this posting: https://www.sl113.org/forums/index.php?topic=30205.msg218776#msg218776
Yes, most likely a good idea to change your timing chain
« Last Edit: May 06, 2020, 07:44:00 by mbzse »
/Hans S
mistertj
« Reply #4 on: May 06, 2020, 10:59:38 »
Thank you.
