Author Topic: quick question on warm running device  (Read 2568 times)
mcclainjlkcmsncom
« on: April 30, 2020, 12:58:04 »
My WRD thermostat extends only 4mm it is not enough to shut off air.I thought I read somwhere that it should extend 7mm.I believe it is the newer type on a M130 1972 engine.Does anybody know the part number and who sells it.
Thank you in advance.
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: quick question on warm running device
« Reply #1 on: April 30, 2020, 13:43:26 »
Check this out. You might have get a different spacer or modify your exIsting one for newer thermostats.
https://www.sl113.org/forums/index.php?topic=16107.0
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
col320ce
« Reply #2 on: May 01, 2020, 12:48:46 »
Part # 0012039575
Not too expensive either. Sounds like yours needs replacing.
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
And George, the infamous 1992 Ford Laser
mcclainjlkcmsncom
« Reply #3 on: May 01, 2020, 18:06:55 »
thanks for replies.I took it apart and polished alum slide piece and it seems to work better will install it this weekend.
« Reply #4 on: May 01, 2020, 18:37:08 »
Thermostat is available at MB. Not too expensive as mentioned.
col320ce
« Reply #5 on: May 01, 2020, 22:30:20 »
Also make sure that the inside of the housing is clean of all the rust that can accumulate there.
Col
1964 230SL
1965 250SE coupe
WRe
« Reply #6 on: May 02, 2020, 07:23:53 »
there are several brands on the market: Mahle -28€, Behr -49€, Bosch -98€ and MB -135€.
...WRe
