Become a
Full Member
Emergency Contact List
quick question on warm running device
Topic: quick question on warm running device (Read 2787 times)
mcclainjlkcmsncom
April 30, 2020, 12:58:04 »
My WRD thermostat extends only 4mm it is not enough to shut off air.I thought I read somwhere that it should extend 7mm.I believe it is the newer type on a M130 1972 engine.Does anybody know the part number and who sells it.
Thank you in advance.
mrfatboy
Associate Member
Platinum
USA, CA, Rancho Santa Fe
Re: quick question on warm running device
April 30, 2020, 13:43:26 »
Check this out. You might have get a different spacer or modify your exIsting one for newer thermostats.
https://www.sl113.org/forums/index.php?topic=16107.0
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
col320ce
Full Member
Gold
Australia, Victoria, Glen Iris
Reply #2 on:
May 01, 2020, 12:48:46 »
Part # 0012039575
Not too expensive either. Sounds like yours needs replacing.
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
mcclainjlkcmsncom
Reply #3 on:
May 01, 2020, 18:06:55 »
thanks for replies.I took it apart and polished alum slide piece and it seems to work better will install it this weekend.
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #4 on:
May 01, 2020, 18:37:08 »
Thermostat is available at MB. Not too expensive as mentioned.
col320ce
Full Member
Gold
Reply #5 on:
May 01, 2020, 22:30:20 »
Also make sure that the inside of the housing is clean of all the rust that can accumulate there.
Col
1964 230SL
1965 250SE coupe
WRe
Full Member
Platinum
Germany, Hessen, Seeheim-Jugenheim
Reply #6 on:
May 02, 2020, 07:23:53 »
there are several brands on the market: Mahle -28€, Behr -49€, Bosch -98€ and MB -135€.
...WRe
