Please check out joining the
Emergency Contact List
for help during your travels!
Adjusting Tappets
Topic: Adjusting Tappets (Read 3014 times)
col320ce
Full Member
Gold
Australia, Victoria, Glen Iris
Adjusting Tappets
April 12, 2020, 09:56:43 »
I've read the BB and the guide on this website and I can't find where it says if the spring clamp on the rocker arm should be removed or not when adjusting the clearances. The guy on 'MercedesSource" says they should be... and I can confirm that it makes a difference if the spring is present or not to the gap.
Thanks for any comments...
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Pagoda SL Board
Platinum
USA, CA, San Marcos
Re: Adjusting Tappets
April 12, 2020, 14:32:59 »
I have done this several times, using the valve adjustment tour. You should not need to remove the springs. At least when my friend and I did this, we did not remove the springs.
I will be most curious to see what others have done.
kampala
Full Member
Platinum
USA, CA, Hermosa Beach
Reply #2 on:
April 12, 2020, 16:59:06 »
I have not had to remove slings. Have followed the excellent valve adjustment tour. Since you are a full member you have access to the best resource for this:
https://www.sl113.org/wiki/Restricted/ValveAdjustmentTour
250sl - later - manual
280sl - 1971 - Auto - LSD
Vendor
Platinum
USA, TX, Dallas
Reply #3 on:
April 12, 2020, 17:18:12 »
Not sure why you would want to remove the springs. It would cause more movement in the arm when using the feeler gauge and I can’t imagine that being good.
Full Member
Platinum
Poland, Mazowieckie, Konstancin-Jeziorna
Reply #4 on:
April 12, 2020, 17:37:42 »
Exactly, I was thinking: why would you do that, this is what is holding the tappet in place. I am not sure why Kent did that - can you send a link or was it a VOD?
col320ce
Full Member
Gold
Reply #5 on:
April 12, 2020, 23:04:38 »
Here's the video link. He says it at 3:00
https://youtu.be/naB8TeL4eOk
Col
1964 230SL
1965 250SE coupe
Full Member
Platinum
USA, OH, Blacklick
Reply #6 on:
April 12, 2020, 23:05:16 »
It's not necessary to remove the springs. Of coarse it is allowable if you like to do things the hard way
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #7 on:
April 12, 2020, 23:25:55 »
It's pretty easy to knock them off while working in there so I do it either way. On a fresh rebuild, I leave them off until I'm done.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Full Member
Platinum
USA, CA, DeLuz and France, Haute-Marne, Guyonvelle
Reply #8 on:
April 13, 2020, 02:31:33 »
I do remove the little springs, not a big deal. Will try leaving in place next time.
Full Member
Platinum
Reply #9 on:
April 13, 2020, 13:20:23 »
Just went through BBB - no removal of springs mentioned for our engines. The only place where it is mentioned is for some type of engines and some type of tools. Then there is a passage reminding to put them back on.
Adjusting Tappets
