Author Topic: Adjusting Tappets  (Read 3011 times)
col320ce
Adjusting Tappets
« on: April 12, 2020, 09:56:43 »
I've read the BB and the guide on this website and I can't find where it says if the spring clamp on the rocker arm should be removed or not when adjusting the clearances. The guy on 'MercedesSource" says they should be... and I can confirm that it makes a difference if the spring is present or not to the gap.
Thanks for any comments...
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Re: Adjusting Tappets
« Reply #1 on: April 12, 2020, 14:32:59 »
I have done this several times, using the valve adjustment tour. You should not need to remove the springs. At least when my friend and I did this, we did not remove the springs.
I will be most curious to see what others have done.
kampala
  • USA, CA, Hermosa Beach
« Reply #2 on: April 12, 2020, 16:59:06 »
I have not had to remove slings.  Have followed the excellent valve adjustment tour. Since you are a full member you have access to the best resource for this:
https://www.sl113.org/wiki/Restricted/ValveAdjustmentTour
250sl - later - manual
280sl - 1971 - Auto - LSD
« Reply #3 on: April 12, 2020, 17:18:12 »
Not sure why you would want to remove the springs. It would cause more movement in the arm when using the feeler gauge and I can’t imagine that being good.
« Reply #4 on: April 12, 2020, 17:37:42 »
Exactly, I was thinking: why would you do that, this is what is holding the tappet in place. I am not sure why Kent did that - can you send a link or was it a VOD?
col320ce
« Reply #5 on: April 12, 2020, 23:04:38 »
Here's the video link.  He says it at 3:00
https://youtu.be/naB8TeL4eOk
Col
1964 230SL
1965 250SE coupe
« Reply #6 on: April 12, 2020, 23:05:16 »
It's not necessary to remove the springs. Of coarse it is allowable if you like to do things the hard way :)
« Reply #7 on: April 12, 2020, 23:25:55 »
It's pretty easy to knock them off while working in there so I do it either way. On a fresh rebuild, I leave them off until I'm done.
« Reply #8 on: April 13, 2020, 02:31:33 »
I do remove the little springs, not a big deal. Will try leaving in place next time.
« Reply #9 on: April 13, 2020, 13:20:23 »
Just went through BBB - no removal of springs mentioned for our engines. The only place where it is mentioned is for some type of engines and some type of tools. Then there is a passage reminding to put them back on.
