Author Topic: Carpet Padding Pattern  (Read 5411 times)
Pastarnac
  • USA, MA, Rehoboth
« on: February 20, 2020, 23:49:36 »
Does anybody has drawings or pictures of the padding under the carpet for a 280SL?
From my research I found that it should be jute 3/8 to 1/2 thick.
When I got the car it had 4 foam pieces ( 2 back + 2 front) which I assume it was mimicking the original padding but that is a stretched assumption.
Appreciate input from those that are knowledgeable in the topic.
mbzse
Re: Carpet Padding Pattern
« Reply #1 on: February 21, 2020, 00:00:16 »
This is original. The thickness is some 7mm, can be compressed slightly.
« Last Edit: March 01, 2020, 00:23:43 by mbzse »
/Hans S
Pastarnac
  • USA, MA, Rehoboth
« Reply #2 on: February 21, 2020, 01:55:19 »
That  is one of them. Good!
a) Which one? Probably Front , which side?
b) Some dimensions would help
johnk
  • USA, OH, Avon
« Reply #3 on: February 22, 2020, 01:16:16 »
Any idea where to buy the original style padding?
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
Aaron h
« Reply #4 on: February 22, 2020, 06:17:04 »
This felt padding shows to still be available from Mercedes.  Part number 000-983-22-92.  It's stupid expensive though.  It wholesales for $170 and retail price is $232.  You get one square meter each.  I have no idea if what is still available has the waffle pattern to it or if it's smooth.
johnk
  • USA, OH, Avon
« Reply #5 on: February 23, 2020, 12:39:44 »
I see that similar padding can be bought online fairly cheaply but not with the waffle pattern. I still have my worn originals to check if they have the pattern.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
specracer
  • USA, MA, Duxbury
« Reply #6 on: February 27, 2020, 01:18:48 »
I got a foil backed jute to assist with the heat on the passenger side.
lowpad
  • USA, CT, New Preston
« Reply #7 on: February 29, 2020, 13:10:30 »
On the earlier cars with rubber mats instead of carpet, was the same jute material used?
1966 230SL (6/66 build)
French export
4-speed manual
158 Exterior / 040 Hardtop
2001 SLK230
1996 Porsche 993
1991 Acura NSX
johnk
  • USA, OH, Avon
« Reply #8 on: February 29, 2020, 14:52:32 »
I first installed the foil backed heavy rubber material for sound deadening which I will spray with black sound deadening to make it not so obvious. I plan on using a jute backed padding next if I can find something reasonable.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #9 on: February 29, 2020, 21:59:16 »
After putting the deadening onto the floors in my car i the took the new floor carpet pieces and made patters and used them to cut out backed felt pads to fit under the carpet.I then got the black bitumen spray and sprayed what was to be the down side so that any moisture would not get into the pad and then contact cemented the pad to the underside of the carpet floor pieces.It worked a treat.
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
« Reply #10 on: February 29, 2020, 22:20:02 »
Looks terrific, but if your car listed is correct, shouldn't it only be a rubber mat in the wheel well?
JB
« Last Edit: March 01, 2020, 13:55:30 by SADIE »
johnk
  • USA, OH, Avon
« Reply #11 on: March 01, 2020, 04:01:59 »
great idea Gary
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #12 on: March 01, 2020, 05:54:18 »
Sadie,
Mine always had carpet since i owned it and when i went to Cabrio.de that is what they supplied with the rubber insert
