Author Topic: Where to buy a new throttle plate/flap  (Read 12664 times)
Re: Where to buy a new throttle plate/flap
« Reply #25 on: February 16, 2020, 04:17:41 »
I agree that you need at least 38 degrees of full advance to get anything out of a 113 engine - any 113 engine, running any of the different ignition systems used on our cars. If anything, the BBB has done more to confuse people about ignition timing specs than anything I can think of. Too many people go away with the idea that 30 degrees at 3,000 RPM should be what you shoot for when that's only what a 051 unit will produce without the extra ignition timing. I've attempted to explain how the late USA system works without any success.
Writing tech information is harder that one might assume and understanding it can be just as hard. It's NOT possible to fix something unless you know how it works. Explaining how it works is the hard part.
1988 560SEC
Berggreen
  • Denmark, Zealand, Gentofte
« Reply #26 on: February 16, 2020, 21:48:53 »
The Map curves between the two are different. Not so different that the car wont run but the starting RPM and point of initial advance relative to vacuum is very different. There are published curves for the 051 distributer on 123’s website. They are very easy to input on the bluetooth version. Basically its just inputing 5 numbers into the fields on the app and hit save. I’ll post my 051 curve below. Note the RPM set point is set at zero. It is not needed with the early/051 throttle body because vacuum control is still retained. 11 degrees of map advance and 22 degrees (not shown) of centrifugal advance with static timing set at 5BTDC for a total advance of 38 degrees.
 This is the one I have had the most success with.
Thanx Tyler for sharing this. Do you also have the points for the mechanical/centrifugal curve? :)
Let me understand, do you actually use vacuum to advance the timing like on the early 230SL's, and thus not for retarding the timing? If so, why is this better than using the vacuum to retard?
As far as I understand, program 8 on the standard 123 still uses a vacuum retard curve. You mention that the program 8 curves are published on the 123ignition website. Do you have a link for these you can share?
I tried to search myself, and I can only find a table with some fix-points for program 8 in the manual for the standard 123ignition, which look like this:
Advance starts: 1000 RPM
Max. advance: 22 degrees/crankshaft at 2500 RPM
Vacuum advance: "10 degrees negative vacuum"
However, it would be great to see the actual curves plotted as graphs. Have you found those on the website?
I did find some 051-curves in the manual for the BlueTooth-version (https://www.123ignitionshop.com/manuals/123_TUNEplus_manual.pdf), and I have attached it here. But I cannot see that these curves match the fix-points above for program 8. Can you? Also, why four curves and not just two - one for mechanical advance and one for vacuum retard? I also find the explanation under Example 2 very confusing. For starters it seems they are missing some minus on the degrees for the vacuum retard, don't they? But still the curves in the graph do not seem to match the points they have in the example. Or do I miss something here.
The BlueTooth 123ignition seems like a powerful tool, but the manual does not help much and is very confusing, same also goes for the manual for the standard 123ignition, which can also be very confusing, especially the table with the curves-points. I am a mechanical engineer by education, and I have big problems understanding what they write, and I guess that is not good for the average user of the manuals.
Thanx,
Christian
02/1971 MB 280SL (aut.) - olive green 291H
11/1970 MB 280SL (man.) - silver 180G
12/1977 MB 350SE (aut.) - deep green 825H
05/1996 MB SL500 (aut.) - black 040
03/1969 Volvo 1800S (man.) - dark green 94
Berggreen
« Reply #27 on: February 16, 2020, 22:32:11 »
Hi Dan
Thanks, but I fully understand how the US timing system on the late 280SL's work with the constant vacuum port on the throttle body giving a constant retard combined with the vacuum drive under the battery suddenly at 2100 RPM cutting all the constant vacuum retard and thus advancing the timing in one go.
However, as it may have been necessary for MB at the time to overcome US emission regulations that came up around 1969-1970, then I cannot see today that this system does any good for performance of our cars. To have a gradual increase in timing advance by a reducing vacuum retard with RPMs, like on the Euro 280SL, seems like a much better solution, which will give a smoother power delivery and engine performance up through the RPMs. I guess that was also why MB maintained this on the Euro 280SL, where they were not pushed by emission regulations. So in my mind, disengaging the US emission control system and replacing it with either an 051-distributor or 123igition combined with sourcing air from the vacuum port under the throttle house, is the best solution for an originally US 280SL, no matter if the emission control system works or not. :)
You mention a "BBB" above. Are you referring to the service manual, I showed some pictures from?
I agree the service manual  timing seems odd, as the degrees showed for idle timing (8 degrees ADTC for US late-280SL, and 3 degrees ADTC for Euro 280SL) do not match what people are normally timing their cars at today.
Also, the ADTC idle static timing would mean that neither the US nor the Euro 280SL would ever reach the 38 degrees at 3000 RPM using neither the 062 or 051 distributors respectively.
Actually, when you read the tables carefully, then for the US 280SL with the emission control system, they state that at 3000 RPM, you should have 25-30 degrees WITH vacuum connected, thus these 25-30 degrees would also include the static 8 degrees ADTC they specify in the table. Thus, they would never reach the 38 degrees, we want today.
Opposite for the Euro 280SL, here they state 30 degrees at 3000 RPM, but WITHOUT vacuum connected, thus also including the static 3 degrees ADTC they specify, but again not reaching the 38 degrees. But I guess for the Euro 280SL it will not make much difference at 3000 RPM, if vacuum is connected or not, because there will not be any vacuum at that RPM anyway, due to the vacuum port being located just behind the throttle plate on the engine side, where vacuum quickly goes away when the throttle plate opens.
But could it be that MB back then intentionally limited the performance of their cars as the standard settings for some reason, which we don't care about today? Any idea what that reason could have been?
I guess we see the same today, where factories limit the performance of their cars, but where you can chip-tune your car and actually pull much more power out, compared to the factory settings, if you want to.
Cheers,
Christian :)
Ps.: See also below the original advance/retard curves for the 051 and 062 distributors, sourced from the service manual.
« Last Edit: February 16, 2020, 23:24:56 by Berggreen »
« Reply #28 on: February 16, 2020, 23:54:45 »
Hi Dan
Cheers,
Christian :)
I see too much confusion between euro and USA systems and just as much confusion between with and without vacuum. Then there's vacuum advance and vacuum retard which is even more confusing to many readers. Let me try and break this down a bit:
The USA system, when working properly, will give you 38 degrees of full advance. Set your timing to 3 degrees ATDC and a properly working system will do the rest. All other systems should be set to 8 degrees BTDC at idle.
All systems, VA or VR, should always be run with vacuum lines hooked up. Removal of vacuum lines is ONLY for testing purposes.
Vacuum advance and vacuum retard both result in timing advance and it's the method of how that's achieved that's different. Vacuum retard doesn't actually retard your ignition timing it simply moves the advance plate inside your distributor to zero or to the no advance position at idle or under 2,200 RPM with the USA system. Every one of the three different systems used on our cars behaves in unique ways but all of them accomplish the same end results; ignition advance. How that happens may be different but the results are the same.
Figure out which system you have and concentrate on getting that to work. For the sake of your own sanity ignore all others.  ;)
As I've said a number of times, it doesn't matter which system you use but it does matter that you make sure all of the parts of your system match and that they will all work together. If you only change one part of your entire system, will it work and be compatible with all the other parts? There are about four different ignition coils that are commonly used on our cars and each do very specific jobs. Some coils require no ballast resistors while others do and each one of them uses a different amount of resistance.
Before you start spending money upgrading your system become familiar with what you have right now. It might be better than you think.  :)
1988 560SEC
Berggreen
« Reply #29 on: February 17, 2020, 00:44:12 »
Thanx Dan, I fully agree, but I am just trying (as an engineer - sorry I know we can be a pain in the ass! ;) ) to understand how to read and understand the tables from the service manual. I do understand how the physical system works with advance and retard and what the highly valued experience (like yours :) ) says in terms of timing values - so that is not the issue for me. :)
But by looking at the numbers in the table, I am puzzled how MB could reach 38 degrees BTDC, with the adjustment values stated in the tables.
A part of this is also the static timing. I follow that experience says that without the US emission system 8 degrees BTDC is good, but in the tables both the US and Euro 280SL use ADTC values for static idle timing:
US: 8 ADTC
Euro: 3 ADTC
I am using BTDC static idle values and reach around 35 BTDC at 3000 RPM on both of my 280SL’s with 123ignitions and disengaged US emission control systems, and it works well - except for the effects of some missing euro throttle houses (both have US throttle houses at the moment), but I have found two euro’s on EBay and will install them soon.
But again I am just puzzled, why the service manual says something different than what we experience works well, both in terms of the static timing as well as the rest of the test values in the tables.  :o
Hope you can help to satisfy my curiosity! ;)
Cheers and thanx,
Christian
bracurrie
  • USA, TN, Nashville
  • The SL to have is a 113, but I don't have one.
« Reply #30 on: February 17, 2020, 01:03:04 »
Hi Dan
Cheers,
Christian :)
Christion,
I have gone over this with Dan several times.  I have observed the full 38 advance even with my retardation system hooked up. Going by the published material I still do not see how timing advance on the 1970 model US M130 engines with 061/062 distributors could go past 34 or so degrees. It does make sense that the engine would thrive with 38 degrees after all the carburetor version of the M130 seems to get that much advance.   I have my 1970 M130 US version with 061 distributor set at 8 degrees BTDC at 900 RPM and it tops out at 31 degrees at 3000 RPM all with the retardation system disabled. I have been told that 12 degrees BTDC could work which implies that I will get to 35 degrees at 3000 RPM.
I REALLY want to get a 123 ignition programmable distributor and enable the vacuum connection to the throttle body like it is with an 051 distributor.
1970 280 SE W108.018
M130.980 w/ US emissions
manual column shift
Berggreen
« Reply #31 on: February 17, 2020, 01:19:19 »
Christion,
Thanx, and interesting that you can’t get more than maximum in the low 30’es BTDC by combining the values from the service manual.
I have a suspicion that MB deliberately under-tuned their cars with the standard settings in the service manual for some reason, but that 50 years of experience by mechanics have shown that the performance can be improved by up-tuning to reach 38 BTDC.
For your car, why not connect the vacuum retard system again which will lower your current static idle timing, but then adjust static idle timing up to 5-8 BTDC? That would give you more advance at 3000 RPM, even with a US throttle house and the emission control system disengaged or not working.
« Reply #32 on: February 17, 2020, 06:20:33 »
I just rebuilt a 062 distributor so I made note of what it was doing on my testing machine. The mechanical advance moved 20 degrees and the vacuum portion moved 22 degrees for a total of 42 degrees of movement. 42 degrees allows for a lot of distributor movement - in this case ATDC and still give a proper full advance. Everything is built into the distributor and all you need to do is set your ignition timing at idle and if it's all working it will be just fine.
Setting your ignition to 3 degrees ATDC will give you a total of 39 degrees with the late USA system. Setting your timing to 8 degrees ATDC will give you 34 BTDC. I don't recommend anyone setting to 8 degrees ATDC because not only will you have a low idle speed you won't get enough timing for full advance. Any timing ATDC will make your engine run hot at idle and that's not a what you want. I have yet to see one of these engines without a warped head during a rebuild.
1988 560SEC
Berggreen
« Reply #33 on: February 17, 2020, 07:13:55 »
Thanx Dan, ok that seems to match the max. curves for the 062 from the service manual, I posted above and again below. Here the curve for mechanical advance tops out at 23 degrees and the vacuum curve also at 23 degrees.
So even though I agree the 8 ADTC from the service manual is not recommendable, it does start to add up. 23 x 2 = 46 minus the 8 ADTC gives you 38. However, this is using the max. curves for mech. and vacuum, and to reach the test values in the table MB has most likely used the average values from the curves which are 20 degrees for both, thus 40-8=32. Still a little higher than the 25-30 degrees test value at 3000 RPM they specify in the service manual, but we are getting closer. ;)
The 8 ADTC and the 25-30 at 3000 RPM are probably not something MB was happy to specify, but they was forced to in order to squize into the new emission allowables in the US with the W113, which in 1970-71 was singing on its last verse anyway with the r107 coming up in late 1971 with a whole new era of engines better able to comply with strict emission control demands especially in the US.
Today with our cars not having to worry about emission (at least not yet!!), it makes a lot of sense to convert into the euro 280SL system with an 123 to avoid the points etc. and use BTDC idle timing. All to improve performance and driving experience in our great cars! :D
Cheers,
Christian
Berggreen
« Reply #34 on: February 17, 2020, 09:47:55 »
As a side-note, it is interesting to note by comparing just the 062 and 051 distributors alone, that if you disengage all US emission control systems, and can actually source the necessary vacuum somehow, the 062 has much more max. movement and advance compared to the 051:
062: 23 (mech) + 23 (vacuum) = max. 46 degrees + static timing
051: 22 (mech) + 14 (vacuum) = max. 36 degrees + static timing
So if you want to stick to the old BOSCH distributors and really want to tune your M130 engine, and need a lot of max. timing advance for that purpose, and can drill a port in the throttle house or manifold, where you can source the necessary vacuum at the right time, then the 062 dizzy would be superior to the 051 in terms of max. advance! :)
Now, that was not what I expected, before looking further into this. ;)
You can of course also do this with the programmable 123ignition, by constructing the mechanical and vacuum advance/retard curves needed for the job.
Cheers,
Christian
bracurrie
« Reply #35 on: February 17, 2020, 12:25:19 »
Cheers,
Christian
On the 061 the action of vacuum serves only to retard the mechanical advance 0 to +23 degrees offset by up to -17 to -23 degrees of vacuum retardation. The action of retardation simply cancels the mechanical advance and if the engine is stone cold or very hot the retardation system is off, which is why it seems that setting the static timing(without vacuum retardation) high enough to get to 38 degrees BTDC timing at 3000 RPM would run the risk of too much advance at lower speeds when the vacuum retardation is off because the engine is cold or too hot.
What I do not fully understand is the amount of vacuum at different throttle and load states. In other words: How does vacuum change when going from idle to opening the throttle with load under acceleration?
manual column shift
Tyler S
  • USA, CA, Encinitas
« Reply #36 on: February 17, 2020, 16:21:02 »
Christian, here is a 123 mech advance  curve you requested. I have since changed the static timing from 8 to 5 BTDC and increased the total mechanical advance. It is very easy to set the actual distributor timing to zero TDC and add/set your starting static timing via the bluetooth APP. Keep in mind every car is tuned different and may or may not be optimal for your situation. The whole point is it is very easy to experiment with the curves and find an optimal setting. The curve below is a good starting point.
 This is on a 250sl replacing a 051 distributer. Vacuum line connected to original throttle body with retard port just behind the throttle plate. (Vacuum falls to atmosphere when throttle is cracked open)
« Last Edit: February 17, 2020, 16:42:36 by Tyler S. »
« Reply #37 on: February 17, 2020, 19:03:54 »
Vacuum retard does NOT retard ignition advance - it's either on or it's off on the 062/61 . It's only the method by which the distributor gets its vacuum signal. The mechanical advance isn't cancelled out by the vacuum system. Vacuum retard is in fact an advance system.
1988 560SEC
« Reply #38 on: February 17, 2020, 19:10:26 »
That's basically what I'm using with my dual point 300SE distributor. This unit is vacuum advance so I had to change my throttle body. I adjusted the flyweights inside my distributor so the mechanical would open a bit slower in case I couldn't get premium fuel.
The unit I use is set up the same way as the 051 with 20 degrees mechanical and 10 degrees vacuum. I add 8 degrees idle timing and then I get 38 total advance.
1988 560SEC
bracurrie
« Reply #39 on: February 17, 2020, 23:56:23 »
Dan, So the diaphragm on the distributor reacting to the vacuum doesn't retard timing?  In a properly operating 062/061 with speedswitch and vacuum retard, what would timing be at idle with vacuum turned off at cold start? We know it is supposed to be 8 degrees ATDC with vacuum at idle.
manual column shift
Tyler S
« Reply #40 on: February 18, 2020, 02:28:22 »
Quote
The answer lies in the BBB distributer curve chart posted above for the 061/062 distributer. The vacuum portion of the distributor has about a 20 deg range.
So at an 8 ATDC static timing setting with no vacuum the advance would be 12 degrees BTDC.
(-8+20=12)
« Last Edit: February 18, 2020, 02:35:47 by Tyler S. »
Berggreen
« Reply #41 on: February 18, 2020, 22:36:49 »
GREAT, thanks a lot Tyler! :D
What differences in performance have you experienced between using both mechanical and vacuum advance like your curves above, compared to mechanical advance and vacuum retard, similar to the eg. the 051?
Tyler S
« Reply #42 on: February 19, 2020, 00:11:37 »
My setup still uses the port on the throttle body that was used for my 051 distributer. So in effect it is still a retard style system. Thats why the curve on my 123 looks backwards. Either way the end result is it functions the same. I do have the curve set to slightly reduce the advance at lower rpm. Mostly because my head has been shaved and my compression ratio is higher than spec.
The biggest gains were in engine starting, idle quality, and light cruise.
The curve I made and experimented with for the later 061/62 throttle body setup seemed to give the car a little more punch at passing speeds. But without a Dyno its all by the seat of your pants so ymmv.
You need to build your curve appropriate to the type of vacuum supply you are giving the 123. (Throttle body type) Otherwise it wont work correctly. Once set and functional you can go back at any time and add or subtract points or degrees on the curve to tailor to your engine.
« Last Edit: February 19, 2020, 00:21:33 by Tyler S. »
« Reply #43 on: February 19, 2020, 00:30:29 »
(-8+20=12)
I think that's where some discrepancy is coming from. Not every 062 distributor works exactly the same. Some have 20 degrees mechanical and some have a bit more than that. The vacuum portion on 062 units is NOT adjustable and you get whatever it gives. This unit is designed to work with the late 280 engine and is not compatible with earlier systems.
The 051 usually has about 18 - 22 degrees mechanical. I test this function on my distributor tester and then I adjust the pull rod on the vacuum cell until I get the right amount of total movement, or in this case 30 degrees. Add 8 degrees BTDC at idle and you will have the same 38 -39 degrees BTDC as the 061 at full advance.
1988 560SEC
