Author Topic: Bulbs remplacement by LEDS  (Read 2452 times)
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
« on: February 09, 2020, 18:15:36 »
 I am fitting new LEDS bulbs  during this Rainy storming Sunday….
First  taking off the glass, it's easier with a brass wire and a shaft with avoid finger injury :
You have only to pull the wire and then push the tab backward out of the glass
The new LED have a  metallic adaptator ring in which 3 tabs must be located. You must cut the outside of the 3 tabs  before fitting :
Then you can fit the bulb holder with the bulb on the casing:
Before fitting the whole headlight on the car i Wonder if i must put some sealant in the groove of the rubber seal before ?
(after a good cleaning of course…) it seems that there was Nothing in the groove when i have taken the old seal off
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
alpina
  • Spain, Asturias, Villaviciosa
Re: Bulbs remplacement by LEDS
« Reply #1 on: February 09, 2020, 18:24:15 »
I replaced with LEDs in 2017. There is no need to remove the glass.
https://www.classiccarleds.co.uk/collections/headlight-led-bulbs/products/latest-led-headlights-p45t
yves
« Reply #2 on: February 09, 2020, 19:36:25 »
The seal between the glass and the "casing" was cracked and dried ….also i wanted to check the paint behind the headlight ( 10 years without a visit…) :-\ and i found a paint Bubble at the Bottom so i'll have some paint work before it becomes worse...
