Author Topic: Subframe mounts - 280SL  (Read 3283 times)
Benz280
  • USA, NJ, Jersey City
« on: October 28, 2019, 16:44:42 »
Can anyone share the amount of time required to do Subframe mounts ( both Sides )
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Re: Subframe mounts - 280SL
« Reply #1 on: October 28, 2019, 21:02:38 »
A very experienced person can do it in 1 to 1.5 hrs each side, on a nice clean car, in good working conditions, with proper tools and lot of experience. Otherwise double the time.
« Last Edit: October 28, 2019, 21:09:54 by ja17 »
behnamlaw
« Reply #2 on: October 28, 2019, 23:15:02 »
spray and soak the bolts overnight
I say a full day leisure Saturday 9-4 with lunch and slow pace  and a cold beer at the end
if bolts are not frozen of course
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #3 on: October 29, 2019, 00:00:09 »
I found a good sized prybar helped - mine is 6' long and was enough that I could do the work myself very easily- oh yeah - make sure you are at least 5' away from another car or the wall so you can use all 5'.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
« Reply #4 on: October 29, 2019, 05:19:27 »
Yes, the pry bar is a big help as you will see!
« Reply #5 on: October 30, 2019, 17:17:40 »
On one occasion (for a member here) I found the mounts sufficiently seized in place that I had to use oxy-acetylene heat to remove them.
