Author Topic: Injection pump calibration data  (Read 6660 times)
mauro12
  • Italy, Sicily, Messina
« on: October 28, 2019, 13:36:03 »
Hello guys, I’m in the process to overhaul the injection pump , but my Bosch local dealer asked me to provide the data sheet regarding fuel flows etc at different rpm in order to calibrate the pump. Do you know where I can find in English? Thank you
Mauro Pisani
250sl 1967 5speed zf manual
Re: Injection pump calibration data
« Reply #1 on: October 28, 2019, 15:44:16 »
Your dealer should be able to get that info from Bosch.
« Reply #2 on: October 28, 2019, 16:14:28 »
I have a 30 page manual for repair which I can forward.  Send me a private message with your email and I'll send it onward.
Jeff
« Reply #3 on: October 28, 2019, 18:50:21 »
Great, thank you!
« Reply #4 on: October 28, 2019, 22:20:56 »
When I was looking I found that it was a closely guarded secret held by a few people that rebuild these pumps.  If anyone comes up with anything I would love to see it.
« Reply #5 on: October 28, 2019, 22:44:04 »
Even if you have rebuilding info it won't do you much good without the test sheets. This is info supplied by Bosch to authorized dealers so that they can tune the pump to factory specs. In order to do this you need test equipment and the ability to do it. This isn't a job for a novice regardless of best intentions.
If you want to get into rebuilding fuel injection pumps then learning how to work on them makes more sense. If you want to have your pump rebuilt send it to an expert.
Sorry if this isn't the answer everyone was looking for.  :(
mnahon
  • Canada, QC, Montreal
« Reply #6 on: October 29, 2019, 01:47:59 »
This site has some info, including data sheets, but not quite of the W113 pumps. If you scroll down, there are data sheets for Mercedes R12 and R19 pumps. Maybe if you contact the author, he has access to the sheets for your pump. I assume the data sheets are different for each model number.
http://911mfi.com/5.html
Meyer Nahon
Montreal, Canada
2021 Tesla Model 3
Taleb
  • USA, NY, SPRINGFIELD GARDENS
« Reply #7 on: October 29, 2019, 10:01:19 »
Hi ,
I will not risk it with anyone . If you are in united state send it to H&R fuel injection (Marty +1 631 589-1600 ) or www.yankeedieselinc.com . They will charge about 200$ for perfect calibration. And 1700$ for complete rebuild.
Good luck.
mauro12
« Reply #8 on: October 29, 2019, 18:57:36 »
What’s the difference between simple calibration and rebuild? Mine is running normally but the co% is too high and fuel consumption is about 12mpg. Other things are right so the last option is the pump
Mauro Pisani
mbzse
« Reply #9 on: October 29, 2019, 23:15:53 »
Quote from: mauro12
What’s the difference between simple calibration and rebuild?.../...
Take a look at this picture, showing the large amount of parts that make up the Bosch injection pump in our Pagoda cars.
It is like a Swiss watch inside, intricate design and precisely machined components.
Imagine the amount of work and expertise needed, to remanufacture the item. Hence high cost.
A problem today is to find the spare parts needed, very limited supply...
/Hans S
« Reply #10 on: October 30, 2019, 16:24:14 »
Yes and it was designed without the aid of computers! Amazing.
mauro12
« Reply #11 on: November 02, 2019, 13:42:52 »
I guess you need a total rebuilt when the pump is not working at all. In my case the pump is running normally but rich. Maybe a worn out thermostat or simply the screws need to be set up.
If I can I will send here a link of a French Tv show called wheeler dealers france, they restored a 250se pump for a total cost of 1100€ and that’s the kind of service I think I need. Put from min 25’.
https://youtu.be/fkhz-1Mz_Ck
Mauro Pisani
