with our official
Pagoda SL Group logo
from our official partner.
Hard Auto Box Upshift between 2nd and 3rd gears
Topic: Hard Auto Box Upshift between 2nd and 3rd gears (Read 2542 times)
Nicolas Aristodemou
Full Member
Senior
Cyprus, Lefkosia, NICOSIA
280SL Auto 1970 W113, 380SL Auto 1982 R107
October 19, 2019, 15:35:09 »
My 1970 US spec 280SL seems to be managing all the upshifts and downshifts extremely well (almost like a modern car) apart from the upshift between 2nd and third gear (during normal driving with shifter in position 4, taking place at around 2500 rpm when starting from a standstill) which is not smooth like all the other gear-changes. This particular gear change is not accompanied by any noise it is just jerky. When I press the car harder from standstill so that this first gear change happens at just under 4000rpm, things are much smoother.
I have changed the gearbox oil and filter but so significant change.
Any ideas as to what could be causing it?
Nicolas Aristodemou
Nicosia - CYPRUS
280SL Auto 1970 US spec (W113), 380SL 1982 R107, Citroen DS23 Pallas 1973, Triumph TR4 1963, Triumph Stag 1973, Mini Cooper S Mk1
1965, Jaguar 3.8 Mk2 1962, VW Beetle 1978 Karman Converible, 1987 Ferrari 328GTS
teahead
Associate Member
Gold
USA, WA, Des Moines
aka "Rob"
Re: Hard Auto Box Upshift between 2nd and 3rd gears
October 19, 2019, 17:08:19 »
probably need to lower the pressure.
Facing the modulator adjustment thing, loosen the 10mm nut, and turn with a pair of pliers counter clockwise some. PITA to get under there and w/that heat shield almost in the way, but can be done.
Nicolas Aristodemou
Full Member
Senior
Reply #2 on:
October 19, 2019, 17:37:49 »
Thanks for the suggestion. Will take the car to my mechanic to lift it up for me and will try this adjustment..... see the result....next week.....
Nicolas Aristodemou
Nicosia - CYPRUS
Nicolas Aristodemou
Full Member
Senior
Reply #3 on:
November 08, 2019, 10:32:24 »
I had a chance to lift up the car today and adjust the modulator pressure on the assumption that the hard shift between 2nd and 3rd gears was due to a high gearbox operating pressure (>40psi). I don't have the banjo fitting with the pressure gauge to see what the actual pressure was and didn't want to bother sourcing the parts to fabricate such a set.
As per teahed's suggestion I unscrewed the 10mm locknut on the modulator and turned with a pair of pointed pliers the adjusting screw anti-clockwise by 180 degrees (half a turn).
Result was a much a smoother gearchange from 2nd to 3rd, to the point that I am now happy. Remaining upshifts and downshifts have not been affected since they were initially spot on.
Thanks for the useful advice.
Nicolas Aristodemou
Nicosia - CYPRUS
