Author Topic: Paint for underbody  (Read 5039 times)
230slhouston
  • USA, TX, Houston
Paint for underbody
« on: September 28, 2019, 22:27:27 »
Hello All,
I have seen a few threads on the color and stone chip for the under body. I decided not to remove all the stone chip from the underside since, it is in very good condition and just needs a clean up. Two questions?
1. Is there a beige paint that someone has used to give the factory look. i was thinking of painting it the color of the car (DB50 - white) but thinking against it.
2. There are a few scuffed areas i need to do some minor touch up repair of the stone chip. Which Wurt product will work or is there another product recommended?
Thank you for the help.
Maistran
johnk
  • USA, OH, Avon
Re: Paint for underbody
« Reply #1 on: September 29, 2019, 04:34:15 »
My car was similar just needing touch up in a few areas rather than stripping and recoating, however there was no way I could touch it up to look original so I refinisged the underside the best I could.
The entire body or our cars were originally painted in a grey/green primer which you can closely replicate with a grey PPG primer ( I will get you the number). The under-bodies were then partially covered with a tan Body Shutz on the floor pans and the transmission tunnel up by the engine. The wheel wells were then shot in the body color and a significant amount of body color overspray landed on the underside when the rocker panels were sprayed. A yellowish/orange wax call cosmoline was then sprayed on the bottom of the car turning darker brown over time as it got dirty.
3m makes a body shutz similar to the original tan used by MB. I found a paint called "quazmoline" (you can google the name to find it) that seemed to do a nice job replicating the original look of cosmoline before it got dirty with time.
I will take a few shots of how mine turned out and post them tomorrow.
Johnk
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
230slhouston
  • USA, TX, Houston
« Reply #2 on: September 30, 2019, 13:20:50 »
John,
Thank you for the information. would appreciate the paint code for PPG. Car is about to be painted on the underside.
Maistran
« Reply #3 on: September 30, 2019, 16:19:58 »
PPG DP40LF is the gray/green that most use to match the primer color. You would use DP402LF for the catalyst. There are many colors in that line 90 - black, 48 is white, 50 is grey, etc.....
Also, see this post https://www.sl113.org/forums/index.php?topic=27806.msg200118#msg200118
« Reply #4 on: September 30, 2019, 18:00:59 »
DP40LF and U-Pol Raptor bed liner.  The Raptor is tintable to match.  After looking at quite a few cars.  There is quite a range of colors on the undercoat from white to grey and beige.  Mine was almost white.
I almost hate to admit this but I bought about 8 different undercoating materials and 3 different spray guns.  In terms of matching the original the Raptor was the best by far. It was the only one I could get the thickness and texture out of.  Any air dried product I tried dried down so much I couldn't get a good buildup. Add to that it is Catalyzed and won’t slough off if you ever have a fuel leak and it is dynamite stuff.
« Last Edit: September 30, 2019, 18:16:16 by Shvegel »
dirkbalter
  • USA, CA, Corona
« Reply #5 on: September 30, 2019, 18:40:08 »
I sprayed U-Pol Gravitex HS Stone Chip Protector. It was recommended and discussed here in the forum at one point.  It is paintable and sprayed with a special (non expensive) gun, straight out of the bottles.
Looks very similar to the above pics. Like it a lot.
« Last Edit: September 30, 2019, 21:44:48 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
johnk
  • USA, OH, Avon
« Reply #6 on: September 30, 2019, 21:33:44 »
A few pics of my results below. The first one is after having cleaned and scrubbed the original undercoating and then spraying DP40 where paint/Primer was visable originally. The second is after spraying the 3mm body Shultz which is similar in color to the original shultz. The third picture is after spraying "quazmoline" meant to imitate the look of the original clean cosmoline. The last is with my overspray from spraying the body color on the rocker panels.
I will be honest that doing it this way is a bit expensive (I think the DP 40 alone was almost $100 a quart) and doesn't look as nice as when you spray the entire underside with the body color. Nobody really looks underneath the car once its put together anyways, even the judges. I guess its just the fun of trying to make it look like new, or some other crazy reason.
JohnK
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
pj
  • Canada, ON, London, Ontario
  • 1965 230SL
    • my home page
« Reply #7 on: October 02, 2019, 01:54:07 »
I don't have special knowledge about what should be correct, but here's the underside of our car, for reference.
Peter J
1965 230SL #09474 named Dagny
2025 GLC300 coupe named Rigel
doitwright
  • USA, IL, Willowbrook
« Reply #8 on: October 02, 2019, 04:26:56 »
This is one of the questions I plan to discuss with Brian Peters from MotoringInvestments this Friday at Pagoda Fest. He is slated as one of the presenters. He has focused on this issue on some of his documented restorations and presented different results. I am curious to know what his opinion is now and how he replicates what he believes is correct. This issue has been reviewed in numerous threads on this site but I feel there has never been an absolute consensus.
Frank Koronkiewicz
Willowbrook, Illinois
230slhouston
  • USA, TX, Houston
« Reply #9 on: October 03, 2019, 17:21:06 »
Thanks Everyone. Hope to get the undercoat tomorrow and get goin going on this. I am so tempted to spray a single stage same as the color of the car and be done with it...DB50 white.
« Reply #10 on: October 07, 2019, 00:58:38 »
A very old thread but where I got most of my underbody knowledge.
