Author Topic: Power steering Installation 1965 230 sl  (Read 5701 times)
Derm Cain
  • Canada, Newfoundland and Labrador, Colliers
« on: September 08, 2019, 23:46:20 »
Would anyone have a schematic of a power steering system or power steering parts schematic for  a 1965 230 SL.  any general information you can offer for installation would be helpful.  My 1965 230Sl came w/out P/S.  I now have most parts to install one.  Pictures from a parts book or service manuel would be helpful.
Re: Power steering Installation 1965 230 sl
« Reply #1 on: September 09, 2019, 04:13:38 »
Do you have the power steering column from a 230SL? Nothing else will work.
« Reply #2 on: September 09, 2019, 13:50:59 »
Jim Villers did an extensive write-up on this subject years ago when he added PS to his 230SL. You may be able to search up his posts. In his case he had his original steering column cut and shortened then welded. The steering shaft is the tough part to source in the puzzle.  Alfred Esser's 230SL, in his case he found a new PS steering shaft.
mBdrvr
  • USA, PA, Bethlehem
« Reply #4 on: September 11, 2019, 22:22:55 »
Attached is a Service Information (technical service bulletin) regarding the the installation of power steering in a 230 SL from December, 1964.
Added to tech manual here: https://www.sl113.org/wiki/Steering/Start under Maintenance
« Last Edit: September 12, 2019, 10:23:13 by Peter van Es »
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
« Reply #5 on: September 12, 2019, 10:22:35 »
mBdrvr Great.. I've added the two attachments as a single PDF to the Tech Manual here: https://www.sl113.org/wiki/Steering/Start
To conserve space I am deleting them from your post...
« Reply #6 on: September 12, 2019, 16:33:25 »
Thanks mBdrvr and Peter, great information!
mBdrvr
« Reply #7 on: September 12, 2019, 16:37:31 »
I acquired a 5 volume set of "Service Information" technical service bulletins from the 60's and 70's. Although many of them are for other models, there are many that relate to W113 and W111 vehicles. I also have a two volume set for "Special Tools".
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
« Reply #8 on: September 12, 2019, 23:29:14 »
Quite valuable. A lot that information is not even in the BBBs.
« Reply #9 on: September 13, 2019, 09:26:37 »
mBdrvr - Paul,
if there are any that pertain to our cars... you'd do us a great favour if you scan them (to PDF) and https://wetransfer.com them to me (admin@sl113.org) and I can upload them to the Technical Manual and make them available for all (Full) members.
Great winter project!
« Reply #10 on: September 13, 2019, 17:34:48 »
Dear Peter,
I did not find on our side the BBB (in pdf).
Would this be possible for members?
Would be very nice!
Or is it there and I missed it.
mBdrvr
« Reply #11 on: September 13, 2019, 18:08:25 »
I'll go through them and send the ones that pertain to the W113 and W111.
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
« Reply #12 on: September 14, 2019, 12:38:16 »
Would be very nice!
Peter, the BBB is not on our site (except for some small excerpts).
The reason is that MB Classic Center still sells it Werkstatthandbuch ab Baujahr 1968, W 108 - 113 (deutsch), it is copyrighted, and Mercedes Benz would put us out of business quicker than you can say 'Bye Bye'.
That does not mean that you cannot find (illegal) CD's with badly indexed versions of this BBB on eBay. But we will, and cannot post them on the site.
MikeSimon
  • USA, OH, North Royalton
« Reply #13 on: September 14, 2019, 18:15:59 »
Sorry to say this, but IMHO the BBB is quite useless for most jobs on our cars. I have both and cannot find much in either of them that I can't find a better explanation for in a Haynes or on-line.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Tyler S
  • USA, CA, Encinitas
« Reply #14 on: September 15, 2019, 18:04:13 »
The TSB’s (Technical Service Bulletins) would be of great interest. There were factory authorized modifications done by dealers to cars in order to solve issues. Some of these could be interpreted by a judge or restorer as being “incorrect” when in fact they should be allowed. Case in point is the rubber buffer strips added to the rear chrome on the trunk sill and tail lights on later cars. My 250 has had these buffers for as long as my family has owned the car since early 80’s even though it is an “incorrect” modification. I believe there was a MB TSB to address water intrusion by adding these to earlier cars when a complaint was made. Would be nice to see it!
« Last Edit: September 15, 2019, 18:12:09 by Tyler S. »
Derm Cain
« Reply #15 on: September 16, 2019, 13:05:35 »
Thank you for the reply and information.  Very much appreciated
mBdrvr
« Reply #16 on: September 16, 2019, 18:41:04 »
I will copy the TSB's to PDF format. It will take some time however.
Paul
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
Derm Cain
« Reply #17 on: September 17, 2019, 23:49:37 »
would you know how to reach Jim Villers?
neelyrc
  • USA, AL, Birmingham
« Reply #18 on: September 18, 2019, 12:55:57 »
You could try a PM.  He is a member here.  Forum name: JimVillers
Ralph
1972 Mercedes-Benz 280SEL 4.5
1988 Mercedes-Benz 560SL
2007 BMW 328xi (E90)
Italy
2004 Toyota HiLux D4D Pickup
Derm Cain
« Reply #19 on: September 19, 2019, 00:51:20 »
Very much appreciated, thank you.
