Author Topic: windshield wiper  (Read 4165 times)
rodlilyquist
  • USA, CA, RANCHO SANTA FE
windshield wiper
« on: July 09, 2019, 15:58:54 »
The windshield wiper on the driver's side has stopped rotating.  Has anyone had this problem?
Rod Lilyquist
1968 250 SL
Light Blue
teahead
  • USA, WA, Des Moines
  • aka "Rob"
Re: windshield wiper
« Reply #1 on: July 09, 2019, 17:11:27 »
can hear the motor running?  Maybe feel it in the engine compartment?
Or remove the glovebox and see if anything is turning?
Paul & Dolly
  • i Car
« Reply #2 on: July 09, 2019, 19:49:29 »
If the passenger side is working then the motor must be working so it is either the spindle on the driver's side or the linkage on the driver's side to investigate.Remove the wiper arm and see if the spindle is still connected.
You could remove the glove box and have a look to see if the linkages loose anywhere.
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
« Reply #3 on: July 09, 2019, 19:56:15 »
Whoops. Sorry Rod.  I misread your post.  I didn't realize the passenger side was working. Its not the relay 🤪
« Last Edit: July 10, 2019, 21:51:28 by mrfatboy »
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #4 on: July 10, 2019, 21:47:57 »
Possibly the linkage has disconnected. If so the cause may be a stuck spindle or just a worn linkage socket.
johnk
  • USA, OH, Avon
« Reply #5 on: July 11, 2019, 03:30:08 »
mine did the same thing. Stuck spindle for the driver side. Only solution for me was to pull the dash apart to remove the mechanism which I was doing anyways as part of my restoration. I tried lubricating the spindle from the outside with no luck.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
