with our official
Pagoda SL Group logo
from our official partner.
General Discussion
Thermostat Housing
Topic: Thermostat Housing (Read 3561 times)
MP
Full Member
Silver
United Kingdom, England, Devizes, Wiltshire
1967 250sl zf 5 speed. colour 172 anthracite
Thermostat Housing
May 28, 2019, 08:50:52 »
I am having difficulty in re moving the thermostat housing from the head, it seems to be seized onto the studs.
Can anyone help?
Maurice
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
merrill
Full Member
Platinum
USA, TX, Austin
Re: Thermostat Housing
May 28, 2019, 12:56:29 »
hi
if i remember correctly it took me some time to get the thermostat housing off the head in my car the last time i removed it.
not sure if i used an anti seize spray on the long stud or not.
eventually i came free.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
PeterPortugal
Full Member
Gold
Portugal, Faro, Lagoa
Reply #2 on:
May 29, 2019, 11:33:48 »
Kent bergsma - mercedes source on YouTube - has a series of videos on sorting out W113 cars running rich. In one of the very early ones it covers removing the thermostat housing I believe.
1963 220se Cabrio
1968 280se Coupe
MP
Full Member
Silver
Reply #3 on:
May 30, 2019, 09:17:15 »
Thanks for your advice, I have managed to get it off by driving a wedge through the joint ( nervous moments )
Maurice
2000 Ducati 748s
1970 Ducati Monza
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #4 on:
May 30, 2019, 14:29:22 »
I use a bit of heat on things like this. Leaking antifreeze causes this problem and heat will help release the chalky crud that forms between the two dissimilar metals.
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
MP
Full Member
Silver
Reply #5 on:
May 31, 2019, 09:14:32 »
I did try some heat first so it probably helped, good to know I was going the right way.
2000 Ducati 748s
1970 Ducati Monza
General Discussion
Thermostat Housing
