Author Topic: Thermostat Housing  (Read 3562 times)
MP
  • United Kingdom, England, Devizes, Wiltshire
  • 1967 250sl zf 5 speed. colour 172 anthracite
Thermostat Housing
« on: May 28, 2019, 08:50:52 »
I am having difficulty in re moving the thermostat housing from the head, it seems to be seized onto the studs.
Can anyone help?
Maurice  ???
1967 250sl ZF 5 speed
1991 300ce-24 coupe Sportline
1962 Lambretta TV175/ RB20
2000 Ducati 748s
1970 Ducati Monza
merrill
Re: Thermostat Housing
« Reply #1 on: May 28, 2019, 12:56:29 »
hi
if i remember correctly it took me some time to get the thermostat housing off the head in my car the last time i removed it.
not sure if i used an anti seize spray on the long stud or not.
eventually i came free.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
PeterPortugal
  • Portugal, Faro, Lagoa
« Reply #2 on: May 29, 2019, 11:33:48 »
Kent bergsma - mercedes source on YouTube - has a series of videos on sorting out W113 cars running rich. In one of the very early ones it covers removing the thermostat housing I believe.
1963 220se Cabrio
1968 280se Coupe
MP
« Reply #3 on: May 30, 2019, 09:17:15 »
Thanks for your advice, I have managed to get it off by driving a wedge through the joint ( nervous moments )
Maurice :) :)
2000 Ducati 748s
1970 Ducati Monza
« Reply #4 on: May 30, 2019, 14:29:22 »
I use a bit of heat on things like this. Leaking antifreeze causes this problem and heat will help release the chalky crud that forms between the two dissimilar metals.
MP
« Reply #5 on: May 31, 2019, 09:14:32 »
I did try some heat first so it probably helped, good to know I was going the right way.
2000 Ducati 748s
1970 Ducati Monza
