Author Topic: Seat cross members  (Read 2424 times)
swood1
  • United Kingdom, England, Worcester
Seat cross members
« on: March 14, 2019, 15:00:35 »
Hi all,
Just welding in a new seat cross member (the large panel in the middle that the seat bolts too), am I correct in assuming this should be perfectly horizontal to the body otherwise the seats will be wonky?  The new panel I have looks to be too high on the outer edge (closest to the sill), I reckon it's about 10mm too high as supplied  (compared to the original), but shall check again this evening.
Steven
250 SL (early), in bits. Triumph TR4a
Re: Seat cross members
« Reply #1 on: March 14, 2019, 18:45:37 »
Someone in Europe is adding coil springs to the bottom frame of the seat.
swood1
« Reply #2 on: March 15, 2019, 11:50:23 »
I'm not sure that would help with much unless you found the seat too hard...  The better option maybe to add something that would allow for height adjustment surely.
I am going to modify my panels to make them horizontal as cannot see why they would ever need to be sloping.
Steve
