Author Topic: Wire Under Battery. What is it?  (Read 4501 times)
avanwinkle
« on: February 10, 2019, 21:09:58 »
I found this blue wire under battery that is not connected to anything on the tag end.  Need an Id for the wire and purpose if possible.  Thanks.[/img]
« Last Edit: February 10, 2019, 21:25:12 by avanwinkle »
clunker
  • USA, NJ, Chatham
  • 1969 US 280SL 4-speed
Re: Wire Under Battery. What is it?
« Reply #1 on: February 11, 2019, 04:41:19 »
Hi - what is the model/year/etc of this SL? The wiring loom varies across types.
Charles
1969 US 280SL 4-speed Red/Black
DB9 / 981 S / G300 SWB / CB750 / etc
avanwinkle
« Reply #2 on: February 11, 2019, 16:08:15 »
It's a W113 1970.
« Reply #3 on: February 11, 2019, 17:24:43 »
That's the wiring connections for the capacitive discharge box.
« Reply #4 on: February 11, 2019, 21:42:07 »
Could you kindly put that in English?
MikeSimon
  • USA, OH, North Royalton
« Reply #5 on: February 11, 2019, 23:46:14 »
My Owner's Manual has a wiring diagram, which, I must say, is one of the most useless ones I have ever seen as it has no wire color indications.
Anyway, here it is. maybe it is the ground connection from the distributor - item 47.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #6 on: February 12, 2019, 02:23:12 »
Full Membership has its privileges.
There is a colour wire diagram in the restricted area of the Technical  Manual accessible by Full Members.
Membership Administrator
« Reply #7 on: February 12, 2019, 15:27:00 »
I believe the 1970-1971 models featured a rather early design of a CD electronic ignition, by Bosch. CD=Capacitive Discharge.
https://en.wikipedia.org/wiki/Capacitor_discharge_ignition
Anyway, these featured a box that housed the electronics and this box was mounted underneath the battery, hence the wiring that Dan Caron Dr. Benz is referring to. Like all electronics, they don't last forever, and if they go bad they simply aren't worth replacing (good luck finding one and how old is that?) or repairing; you just change to the electronic ignition of your choice--Pertronix, Crane or a 123.
The Crane, by the way, also features a box, and it itself is a derivative of an older Lucas system I'm told. Anyway when I had my Crane, it too was mounted under the battery for a tidy look--invisible.
« Reply #8 on: February 12, 2019, 17:05:01 »
Thank you!
