Author Topic: Correct Distributor for March 1963 220SE Cabrio?  (Read 6294 times)
PeterPortugal
  • Portugal, Faro, Lagoa
« on: December 01, 2018, 09:10:17 »
Hi all,
I have read the excellent posts on checking dwell / timing / vacuum advance etc and am ready to crack on with it on my car.
My car has a Bosch distributor type 0 231 116 049 fitted which according to my workshop manual was the latest one to be used on a 220SE.
Does anybody know if this is correct for a March 1963 car? Chassis W111.023.10.038868?
According to the manual their were 3 different versions of distributor used on the 220SE, each with their own curves. I would be surprised if mine would have had the latest version, certainly this is not the case with the injection pump, intake manifold, thermo time switch, time switch, etc.
1963 220se Cabrio
1968 280se Coupe
PeterPortugal
Re: Correct Distributor for March 1963 220SE Cabrio?
« Reply #1 on: December 04, 2018, 19:17:38 »
Just giving this one a push.
Dan Caron?
1963 220se Cabrio
1968 280se Coupe
mbzse
« Reply #2 on: December 04, 2018, 20:23:42 »
Quote from: PeterPortugal
.../...if this is correct for a March 1963 car.../...
One suggestion would perhaps be, for you to instal a 123 ignition instead (electronic). Use the search function on this website for lots of info on this matter.
http://www.123ignition.nl/
« Last Edit: December 04, 2018, 21:26:53 by mbzse »
/Hans S
PeterPortugal
« Reply #3 on: December 04, 2018, 21:00:07 »
Well that's the second option...
I don't have to rely on my 220SE or use it very regularly so I thought I'd give the original setup a chance !!
1963 220se Cabrio
1968 280se Coupe
mbzse
« Reply #4 on: December 04, 2018, 21:32:09 »
.../...I thought I'd give the original setup a chance !!
Yes, for sure. Perhaps first look at the state of your unit. What could be examined is the centrifugal unit inside (may be siezed up) and the shaft wobble.
/Hans S
PeterPortugal
« Reply #5 on: December 05, 2018, 07:34:31 »
Hi Hans,
The distributor functions OK.
I am doing adjustment of fuel/air ratio, and as per technical manual / forum advice am making sure everything else is adjusted properly first before adjusting the mixture.
There are several different types of distributor shown in the workshop manual for a 220seb and I wanted to verify I had the correct one.
If I do find any mechanical problems (requiring rebuild) with the distributor when I check its function I may well choose to fit the 123 !!
Thanks for your interest !
1963 220se Cabrio
1968 280se Coupe
Aaron h
« Reply #6 on: February 24, 2020, 23:01:26 »
Peter, I may be far too late in responding, but I figure what I post may be useful anyway.
I can't make out from your picture what distributor you have, as the numbers and letters are too blurry/washed out.  However, in the picture below is a page out of the 1963 Technical Data Book.  It denotes which distributors your 220se with the M127-984 engine should have.  You're right in that two different ones were used, but neither the TDB, M-127 book, or EPC give any indication as to which distributor any particular M-127 should or should not have. There are no foot notes or anything.  I guess in this case either would be fine.
« Reply #7 on: February 25, 2020, 03:19:03 »
My guess would be a 49T.  I believe this was also used on the very first 230SL cars as well.  I just did one for a 220SE ( 128 ) cab that I'm working on.
PeterPortugal
« Reply #8 on: February 25, 2020, 12:40:34 »
Aaron / Dan,
Thanks for replying...although old, this topic was not dead !
Based on your replies I will assume the distributor is correct and check it versus the appropriate curves.
1963 220se Cabrio
1968 280se Coupe
« Reply #9 on: February 25, 2020, 17:43:30 »
I have the 49T on my '60 220SE W128 coupe if it makes any difference. I do know of an outfit that specializes in rebuilding Bosch distributors.
Also, if you want a reproduced tag for that distributor, there is a guy in Germany that makes those. I know because he made one for my 49T distributor. I'll try to find his name if you are interested.
PeterPortugal
« Reply #10 on: February 25, 2020, 19:09:30 »
Hi Wallace,
I suspect it is the same guy who also does the data plates for cars. I have used him in the past too.
1963 220se Cabrio
1968 280se Coupe
