Author Topic: wood trim  (Read 3803 times)
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
wood trim
« on: November 28, 2018, 19:40:44 »
Just purchased a set of wood trim from the Classic Center. for a 65 230sl  The radio Grill Cover came with two pre-drilled screw holes.  My present trim does not have any visible screws.  I would expect the Classic Center to be correct but is it?
JB
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: wood trim
« Reply #1 on: November 28, 2018, 22:08:18 »
Yes. There are supposed to be 2 screws that fasten the wood speaker grill to the dash.
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
Jowe
Re: wood trim
« Reply #2 on: November 28, 2018, 22:50:38 »
Well, no for the 230. Instead two pins that goes to clips in the dash. See https://www.sl113.org/forums/uploaded/sjiatrou/2007210203042_SpeakerGrill.jpg
and https://www.sl113.org/forums/index.php?topic=6514.msg40646#msg40646
Johan
mrfatboy
    • Mrfatboy
Re: wood trim
« Reply #3 on: November 28, 2018, 22:53:37 »
Oops. I did not know there was a difference. Thanks for the catch.
Signal Red
4 Speed
wayne R
Re: wood trim
« Reply #4 on: November 29, 2018, 00:28:14 »
Some photos of mine,may also help. just did them a month ago, regards.
wayne R
Re: wood trim
« Reply #5 on: November 29, 2018, 00:32:14 »
2 photos.   2 recessed screws  one at each end.
merrill
Re: wood trim
« Reply #6 on: November 29, 2018, 14:00:51 »
interesting
my 66 230 has the 2 screws...
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
rjmarco
  • USA, CA, Alamo
Re: wood trim
« Reply #7 on: November 29, 2018, 15:18:46 »
My 1965 230 SL has the pins.
Rich
Alamo, CA
Jowe
Re: wood trim
« Reply #8 on: November 29, 2018, 16:32:33 »
The cutoff between pins and screws in the speaker grill was made in beginning of November 1965 from VIN #14090, according to Pagoda Notes Vol. 10 No. 2.
Johan
