Author Topic: Cable end  (Read 4775 times)
Larry & Norma
Cable end
« on: October 10, 2018, 16:10:21 »
Looking for the plastic connector which connects the end of the cable from the gear
selector to the starter inhibit/ reverse light switch on the bulkhead. Uk automatic
RHD car. I think it may be part no. A0009910822. Thanks
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
Re: Cable end
« Reply #1 on: October 11, 2018, 22:06:32 »
Hello Larry,
What you might be looking for and what you refer to by the parts number is  a ball socket,
correct?
BALL SOCKET  -    A 000 991 0822     -    $0.41
Replaced by: A  608 991 0022
BALL SOCKET    -      001    A 608 991 0022     -    $3.31
Found this on Nemiga..., but cannot prove the availability from MB Classic yet.
You might want to try these numbers with your local MB dealer...
Good luck & best,
Larry & Norma
Re: Cable end
« Reply #2 on: October 12, 2018, 10:43:26 »
Thanks for that Achim, the search begins.
Best
Larry
2023 Ioniq6
2005 C230
WRe
Re: Cable end
« Reply #3 on: October 12, 2018, 12:01:21 »
I would assume that's a normal ball socket (plastic or metal with one or two open sides) with a M5 thread like this here: https://www.sls-hh-shop.de/main/en/mercedes-190sl-w121-/07-solex-carburetor/ball-socket-with-rt-hd-threads-p-4378.
...WRe
Larry & Norma
Re: Cable end
« Reply #4 on: October 12, 2018, 12:30:16 »
I will try one of the throttle linkage ones and see if it fits. Could be a solution.
2023 Ioniq6
2005 C230
Re: Cable end
« Reply #5 on: October 12, 2018, 15:45:59 »
That's what I use.
Re: Cable end
« Reply #6 on: October 12, 2018, 18:57:21 »
On my car, LHD - 250 SL, the connector for the transmission linkage cable to the neutral lock out switch has a longer shank (threaded piece) than the ones for the throttle assembly.
