Please check out joining the
Emergency Contact List
for help during your travels!
Excessive crankshaft end float.
Topic: Excessive crankshaft end float. (Read 4517 times)
Vendor
Platinum
United Kingdom, England, Richmond
July 02, 2015, 11:28:02 »
This is interesting!
https://www.dropbox.com/s/t5vhz2llllc79bs/P1040440.MOV?dl=0
Stick
www.colinferns.com
Rolf-Dieter ✝︎
Associate Member
Platinum
Canada, ON, London
Re: Excessive crankshaft end float.
July 02, 2015, 11:53:53 »
Hi Stick,
Is there a thrust plate or thrust bearing to prevent excessive end float? What would be the normal end float you expect? Looks like somewhere in the naighbourhood of 0.062" in your video.
Vendor
Platinum
Reply #2 on:
July 02, 2015, 15:12:58 »
The end float should be 0.1 to 0.24mm.
I haven't bothered getting the tape measure out to measure this particular end float but it's around 2mm.
Stick
www.colinferns.com
Associate Member
Platinum
Canada, ON, Port Lambton
Reply #3 on:
July 02, 2015, 17:10:33 »
I saw that once and they had the locating bearing in the wrong place. This isn't the same engine in another post, is it?
1966 230SL 5 speed, LSD, header pipes, 300SE distributor, ported, polished and balanced, AKA ''The Red Rocket ''
1970 3.5 Coupe
1961 190SL
1985 300CD Turbo Coupe
1981 300SD
2013 GMC Sierra
1965 230SL
Vendor
Platinum
Reply #4 on:
July 02, 2015, 17:38:30 »
Yep!
Stick
www.colinferns.com
Jack Jones
Full Member
Silver
Canada, ON, Milton
Reply #5 on:
July 02, 2015, 20:36:00 »
I also came across this once and found the thrust washers in the oil pan.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
