Author Topic: Excessive crankshaft end float.  (Read 4514 times)
Rolf-Dieter ✝︎
  • Canada, ON, London
Re: Excessive crankshaft end float.
« Reply #1 on: July 02, 2015, 11:53:53 »
Hi Stick,
Is there a thrust plate or thrust bearing to prevent excessive end float? What would be the normal end float you expect? Looks like somewhere in the naighbourhood of 0.062" in your video.
« Reply #2 on: July 02, 2015, 15:12:58 »
The end float should be 0.1 to 0.24mm.
I haven't bothered getting the tape measure out to measure this particular end float but it's around 2mm.
« Reply #3 on: July 02, 2015, 17:10:33 »
I saw that once and they had the locating bearing in the wrong place. This isn't the same engine in another post, is it?
« Reply #4 on: July 02, 2015, 17:38:30 »
Yep!
Jack Jones
  • Canada, ON, Milton
« Reply #5 on: July 02, 2015, 20:36:00 »
I also came across this once and found the thrust washers in the oil pan.
Jack Jones
1970 280SL 4 Speed
1984 280SL 5 Speed
