Author Topic: Tire Nirvana!  (Read 81670 times)
Tire Nirvana!
« on: September 10, 2004, 21:40:12 »
Hello All,
The more research and reading I did on the history of the 113, the more convinced I was that we've got the handling "thing" all wrong...this can be summed up in one quote from Laurence Meredith in his book, "Essential Mercedes SL":
The role played by the newly invented Halbgurtel (half-belted) Continental RA60 radial tires cannot be over-emphasized.  These tires had specially constructed sidewalls to ensure that they remained 'stiff' and as near to the vertical plane as possible under hard cornering.  Early Michelin X radials had proved to be far too flexible when fitted to high performance sports cars like the 300SL, and tended to distort circumferentially during hard acceleration and deceleration, in much the same way as the enormous tires fitted to the back of drag racing machines.  Because the cords used in the construction of the Continental RA60s were wound at an angle below the outer tread, they were not true radials in the modern sense but they certainly made for an acceptable compromise in considerations such as ride comfort and roadhandling. (N.B. The Conti RA60 and Firestone Phoenix were very similar tires and OEM on the 113's)
This is not to say, of course, that we can't improve upon the handling by changing things such as sway bars, bushings, springs, etc. but rather until you have renewed all of these items, AND gone back to the original tires, can we truly understand what the starting point, as it were, of the car's handling should be.  Since my car had the suspension completely renewed during restoration, I could not attribute any of my complaints about handling to the suspension elements; so with this in mind I swapped my Pirelli P400's (in the 205/70-14 size) for a set of Coker's reproduction of the Phoenix which is a true 185HR14.  W O W, what a difference!  The Pirelli's made the car feel disconnected: the body being one part, and the tires/chassis being another.  When I made short steering changes, such as a lane change, it felt like part of the car went and changed lanes, and part of the car was lagging behind.  A real, "loosey-goosey" disconnected feel that even our friend Dr. Benz Dan Caron noticed but couldn't put his finger on when he had my car for service in July.
The new "Phoenix" tires behave I believe, much like the quote above would indicate, and probably quite true to the original intent of the suspension engineers and of course Rudi Uhlenhaut.  They make the car feel connected again.
So, I can highly recommend these tires, with only 2 days of driving on them, only because they made such an astounding difference in the feel of the car.
I'm certainly not suggesting that these are the ONLY acceptable tires for the 113, but I would guess we should have tires with stiff sidewalls.  Aside from these Phoenix, I couldn't even hazard a guess as to how we can tell the stiffness of the sidewalls.  I don't think it is something that is quantified.  Are there other tires out there with stiffer sidewalls?  I'm sure there are...but how to tell? The Pirelli's certainly are not: even the technician operating the Hunter tire mounting machine at Motorwerks in West Bloomfield noticed immediately how much stiffer the sidewalls were on the Phoenix then on the Pirelli--just from the feel of them on the mounting machine.
Nirvana does not come cheap: Pirellis, and Michelins in our sizes are all $50 to $100 per tire depending on model and size.  The Phoenix run $170 each.  But now I feel I am at a point where I can sensibly evaluate any further changes to the handling and suspension.
Re: Tire Nirvana!
« Reply #1 on: September 10, 2004, 22:15:35 »
Mike there was some pretty heated discussion on these tires late August with a not so great rating.  Now you have a completely different outlook on the Coker tire.  Do your tires have the rub strip like the originals?  Do you find them to be noisier than your 205/70/14 tires?
Re: Tire Nirvana!
« Reply #2 on: September 10, 2004, 23:00:00 »
When I changed my tires from Michelin whitewalls to the very same Pirelli P400's Mike just took off his car, I had the same experience: what an improvement! And now it turns out I might be able to improve even further. It goes to show that tires do have a significant impact. One question though - could it be that even within the same tire make/model there are material quality/specification differences?
Re: Tire Nirvana!
« Reply #3 on: September 11, 2004, 00:11:44 »
Cees , Mike has the "New" style tire from Coker.  Is it possible that this tire is so much better than the "old style" tires that Tom found to be substandard?
Re: Tire Nirvana!
« Reply #4 on: September 11, 2004, 02:54:00 »
I have often wondered about the tradesman tyres offered in the original size 185 14 by some companies.
They have a lower speed rating than the HR tyres (who needs a tyre rated at 210Kmph?) but do their sidewalls have the correct construction?
What do they feel like to drive on?
Bob (Brisbane,Australia)
Re: Tire Nirvana!
« Reply #5 on: September 11, 2004, 08:55:19 »
Gents,
I had a long discussion with Coker about these tires...while I can't say for sure how they are manufactured (other then what is noted on the sidewall) I can tell you that the new and old style come from the same mold.  After introducing them (they sell a lot into Germany they tell me) they were asked to incorporate the "rub strip" and they just modified the mold.  My tires do indeed have a very pronounced rub strip.  Pictures will be forthcoming once I get the whitewalls white.
Agreed most of us do not need H rated tires, but that's simply a characteristic and not a reason why I bought them...the fastest I do is about 80 mph, and they feel great.
I have not noticed any more noise, but keep in mind 95% of my driving is with the top down, so the wind noise supersedes all else.
I don't believe that any manufacturer would have specification differences in the tires, but most certainly there are quality differences.  The tires were balanced on a Hunter GSP 9700 Road Force Balancing machine and every tire and wheel were different.  One tire even had a high spot that was just a little out of the machine's spec, and the way to correct this was for the machine to match the tire's high spot with the wheel's low spot--and this brought things into spec.  You can't have this done at Sears!
Obviously I can't speak for everyone's experience with these tires, but I do know that everything, completely in my suspension was renewed during the restoration with original parts.  So I have all original new rubber bushings, rebuilt kingpins, new springs, pads, etc. "the whole nine yards" as it were.  The only things that were not changed were stampings and castings--which were refinished.  So, my undercarriage is as close to "as delivered" as you can get--plus the 2,000 miles I've driven.  So, what I think I have now is a car that drives as close as possible to one delivered in 1969.
My contention is that our cars, with "as delivered" suspensions, will handle better with tires that have stiff sidewalls--as planned for by MB way back when.  As I mentioned, there are probably tires with stiff sidewalls, but how do you find them?
Re: Tire Nirvana!
« Reply #6 on: September 11, 2004, 09:07:25 »
Hauser - I suppose it is possible that the new Coker tires are in fact different. I suppose they would be the one to ask.
What we really need is to do our own comprehensive test, taking one car and then putting different sets of tires on that same car - each time testing them in the same way to arrive at a 'verdict' and ranking. This will eliminate the particularities of different cars' suspension condition + components etc. Actually this could be arranged next time enough Pagodas gather for, say, a tech session!
norton
Re: Tire Nirvana!
« Reply #7 on: September 11, 2004, 09:49:40 »
You should see how well my 280sl drives and handles, with late model MB wheels from a 320SLK (16x7)and 205/55/16 tires, the progressive rate springs,front and rear sway bars + a set of Koni's and the vented brakes from a 280SE. It's like the difference between an ox cart and a slot car. 8)
Re: Tire Nirvana!
« Reply #8 on: September 11, 2004, 12:58:18 »
Well, Norton, with all those modifications to your car, it sure as heck better drive pretty darn well.  However this is what one would call highly modified and does not suit my needs with my 113 as I am trying to maintain it close to original.  However, I would hardly call an original 113 anything like an oxcart.  That moniker is probably best reserved for British cars of the period which had suspensions much like oxcarts of the middle ages...but even our beloved Mercedes had a bit of engineering involved!
Re: Tire Nirvana!
« Reply #9 on: September 15, 2004, 14:58:18 »
Did I understand you correctly that you were able to source WSW tyres WITH rub strips from Coker?  Any chance of posting a picture soon?
Second, the higher the speed rating, the more likely that the tyre will have a stiffer side wall, as directional stability is even more critical at higher speeds.  I have a mid 80's Jaguar XJ6, which specifies a 215/75HR15 Pirelli P6 at about $210 per cover, if you can find them!  I put a set of plain old 215/75r14 tyres on it a couple of years ago and it handled like a pig!  I found a slightly less expensive HR rated alternative to the now obsolete P6s.  The sidewalls were noticeably stiffer and now that 4600 lb. sedan handles like a sports car again.
Originally posted by mdsalemi
Gents,
Re: Tire Nirvana!
« Reply #10 on: September 16, 2004, 07:27:47 »
Hello All,
I seem to have troubles posting photos, but I'll try again.  A "stock" photo of the tire in question can be found on the Coker Website, but I have nice before (Pirelli) and after (Phoenix) photos, as well as some close ups of the Phoenix that I'd be happy to share if I can get them to upload.  I think the issue is I have to one by one disable all the firewall and spam and popup filtering (I've got a ton of these precautions in place and STILL get crap; scams from Nigeria and people trying so sell bootleg software and Viagra!)
There seemed to be an issue with understanding what the rub strip is; my car came with one original Firestone Phoenix (in bad condition and since disposed of)so I have a good memory of what it is supposed to be, and I am pleased with the Coker, very much so.  Not only in handling but in appearance as well.  Now there are those that think WW tires are horrible--just as they think US headlights are awful, and bumper guards as well.  Now we have people disputing the color of the wheel wells.  But the Coker WW are darn near perfect for an accurate, historical look--and drive as well.
I'll try and get the photos up later today.
Re: Tire Nirvana!
« Reply #11 on: September 16, 2004, 08:51:31 »
For a view of an original tire to compare to what is available today, here are photos of a tire with the curb rim and some original color markings...the tire has never been used. The tire was on display last year at the Pagoda gathering at Tom Sargeant's VA home.
Outside Tom's garage was a display of original tires with the curb-protector-rim...the hand points to the curb rim...
Download Attachment: Curb-Rim.jpg
26.66 KB
A never used spare with the original color stripes on its tread...
Download Attachment: Curb-Rim_Marks.jpg
22.17 KB
Richard M
Re: Tire Nirvana!
« Reply #12 on: September 16, 2004, 10:22:45 »
When I was searching for a 280sl about 2 1/2 years ago I found a nice one out in California.  The owner had performed quite a bit of restoration work, new paint, interior and so on.  One thing that stood out about the car was its stance.  The car looked "beefy".  As the seller dscussed all the work which was completed he mentioned the tires.  He said they were the same as used on a Ferrari and said the cost was somethin around the $300.00 range for each!  I have searched Coker tire for such a tire and came up with a 205R14.  Could this possibly fit?
Re: Tire Nirvana!
« Reply #13 on: September 16, 2004, 11:17:52 »
Michael,
You could always e-mail your photos to another member and let them post them.  They need to be under 80 kb in size and the path to them on your PC must be under 150 characters.
Re: Tire Nirvana!
« Reply #14 on: September 16, 2004, 11:21:43 »
Many people use a 205/70r14.  I don't know the side wall ratio on a 205r14.  If it's the same ratio (about 80?) as our original 185r14, then it would be a much taller tire.  If you're going wider, you need a shorter side wall ratio.  I personally have 195/75r14.
  • USA, VA, Alexandria
Re: Tire Nirvana!
« Reply #15 on: September 16, 2004, 17:50:31 »
Group:
After reading Michael's glowing endorsement for this tire, I struggle to explain why he is so pleased with the relative performance while I was so disappointed.  I can only imagine that I switched from a Michelin Symetry ($80+ per tire) to a Coker tire sold as the original Phoenix but with no rub strip.
Michael switched from a Michelin P-400 tire ($50) tire to the Coker tire.
My experience is that the Coker tires road poorly compared to the Michelin and had more road noise.  I can tell the road noise difference because I have a wind screen that cuts the road noise substantially.  Without a wind screen, maybe you would not notice.
So the possible explanations to reconcile two dramatically different views of these tires are as follows:
1.  My tires were defective (this has already been established-no rub strip);
2.  In adding the rub strip, other changes were made to improve the tire.  Maybe the extra rubber from the rub stripe adds structural benefits alone;
3.  The $50 tire rode so bad it made the Coker look good;  remember I am comparing a premium ($80) Michelin tire to the Coker.  Michael is comparing a $50 economy tire to the Coker.
There is a Michelin tire that has the rub strip, but I don't think it comes in a white wall and it is more than the Coker-a lot more.  However, it is a Michelin and you really know the rating you are getting.  With the Coker-not sure what the rating is.  However, I don't think any of us drive our cars so aggressively that the ratings really come into play.
So my tires were either defective and/or Michael and I are comparing apples to oranges.  Probably both.
If you are interested in an original look, but less concerned about performance, the Coker tire is a good option.  If you care about performance and have a premium tire now and are contemplating the Coker tire, you may be disappointed.  Or you may be happy because maybe I just had a bad set of tires.  Frequently the first run of any product produced is not as good as the next run.
« Last Edit: September 16, 2004, 17:53:10 by Tom »
Re: Tire Nirvana!
« Reply #16 on: September 16, 2004, 21:12:24 »
interesting post, Michael.
I have been very happy with my Michelin rainforce 185 r 14 tires.  But, having nothing to compare them to, your experience is worth noting.  Perhaps I don't push my car as much as you.
Best regards,
Don
Re: Tire Nirvana!
« Reply #17 on: September 16, 2004, 22:35:18 »
Maybe next couple of times someone buys a new set of Cokers, they can list their experience here.
I think I posted before that when I changed from old Michelins (plenty thread left, but dried-out rubber) to Pirelli P-400 205's (not so cheap here in Holland, I believe I paid something like $100 per tire), I was very pleased with the results. But that was likely due to the poor performance of the bad Michelins. So this goes to show what Tom is pointing out: how you perceive a new tire depends a lot on what you are comparing it to.
Still think my idea of going through a comprehensive test at the next tech session or other suitable occasion is a good option!
Re: Tire Nirvana!
« Reply #18 on: September 17, 2004, 09:42:27 »
Download Attachment: FRTire.jpg
74.93 KB
Download Attachment: RubStrip.jpg
50.62 KB
Hello All,
Well here are two photos of the Coker's on my car.  One of them is a detail of the infamous rub strip.  The other is an overall picture of the right front tire.  I did notice that the car looked a little different to me, perhaps a bit of an improvement, with the "original" 185's on it as opposed to the "more aggressive" looking Pirelli's in 205, however this appearance look didn't translate well to an 80K photo so they are not here.
I can't really explain the difference in handling other then in matches what was to be expected.  Though the information is over 40 years old, conventional radial tires were examined and rejected by MB as having too flexible sidewalls; the RA60/Phoenix was the answer.  Whether or not anyone can find modern production tires as opposed to reproduction tires with sidewalls as stiff is a matter of testing--I don't think the tire manufacturers publish such information, but perhaps an inquiry on a more advanced level to their technical departments would yield some results.
In reality, with all our cars in various states of repair/disrepair; restored/unrestored, original and altered, every vehicle will feel a bit different with every set of tires. Cees has it nailed 100%.  In our next tech session, we should be doing some tire swapping and anybody willing to make the journey to wherever that might be is welcome to try my Coker's while I try yours.
One must also consider that any kind of change to the suspension has an effect on everything else.  My car has been restored to "original" specs, with original parts, original rubber, original springs etc.  This certainly does not yield the best handling car, but arguably as original as you can get.  The original test reports of the car, which you can read in the Brooklands Gold Portfolio (thanks Doug!) do not give stellar raves about the car's handling.  For example, brake diving which the progressive rate springs correct for, was as prevalent in 1964 as it is in 2004.  Tom Sargeant's car has been in a state of flux with many changes to the suspension as he strives to improve it.  I've had the good fortune to have driven his car and inarguably it feels considerably tighter and better then mine.  If anyone doubts that all these suspension and tire issues don't all interact as a system, think Ford and Firestone.
It should be noted that while the Pirelli P400 205/70 are inexpensive at $51 each from Tire Rack, this is relative: there are only a couple of tires in this size that are more expensive (some Japanese brand I've never heard of and a Bridgestone)and a larger choice for somewhat less.  I didn't buy the Pirelli's because of cost: at the time, armed with a considerably lesser knowledge then I have now, I "upsized" (bigger is better, right??) to the 205; and then searched for WW which is what my car came with when new.  My first problem was when the spare wouldn't fit in the trunk; second problem was at "lock" the 205's had the ability to rub the inner fender well (and take off that body colored paint!! :D )  The Pirelli is noted as a touring tire.  "Performance" tires are only a few in the 185-HR14 size or the 205/70 size.  Add WW as a "requirement" and this drops to zero choice.  There are companies that will put any size WW's on any tire but this gets VERY expensive.
I also don't "push" my car; it hasn't been on a track, and I don't drive it hard.  It is a touring car and that is what I do.  It NEVER leaves here with the top up, but sometimes comes back with it up if mother nature doesn't cooperate.  About the most severe duty it gets is on the autobahns er highways around here where I usually end up doing 75-80mph and let traffic pass me by.  A lane change at speed, or perhaps a quick burst to pass a truck is what I do.  Those lane changes are where I really noticed the tire difference.
We can also note that the Michelin Symmetry does not have a great rating from Tire Rack's customers!  Only 4.4/10 and most wouldn't buy it again.  And, it is a bit more expensive then other tires in size and class; it isn't H rated.  Michelin's sales information says it is a touring tire as well designed for luxury cars, family cars and minivans. Expense doesn't necessarily get you what you are looking for.  The Pirelli P400, on the other hand, has a 6.8/10 and most would buy it again!  On Tom's car the Michelins might just be the best combination.  I can't say anything about road noise but Tom's car is a wonderful driving car, no question.  There was no trace of this disconnected feel in Tom's car, so perhaps the Michelin Symmetry tires would do equally as well on mine...in fact Tom and I almost pulled off a swap until he discovered he already had a set of Pirelli's in his garage! ;)   I'm not partial to Pirelli at all; my preference would have been German-made Continentals, and Michelin's second.  I've had the best luck with Michelins over the years on my other cars.
As for quality, I had a long discussion with Jim Hildebrant of Coker about this tire.  The Coker tire is made in a Michelin certified factory in Mexico.  This means that this factory, which makes Michelin tires as well (maybe even the Symmetry; check the sidewalls for "Made in Mexico"), makes this tire for Coker.  Coker also developed this tire (European members tell us what this means) in conjunction with Valentin Schaal of Munchner Oldtimer Reifen in Munich, Germany specifically for the classic Mercedes market.
Well, let's do some tire swapping at the next tech session!  I'm as interested as anybody in finding out if other less costly tires will feel as good on my car as the expensive Cokers...and my wife would be as well! :)
Re: Tire Nirvana!
« Reply #19 on: September 17, 2004, 11:04:21 »
Before colker tire offered the Phoneix HR  tires for our SLs I went out to fine an exceptable tire for my SL. I talked to many experts who referred me to the Michelin MX4 Rainforce 185R-14 all season tires. While they are not whitewall and do not have an H rating they are the correct size 185 R 14 and do offer good performance for dry and wet traction.
I was very delighted to hear Michael's report on the colker 185 HR 14 Phoneix radials he purchased for his car. Rather than loose sleep over a lost set of fitted luggage to my friend Tom back east, I think I will go out and buy my SL another set of sneakers to wear.
« Last Edit: September 17, 2004, 11:07:48 by Bob G »
Re: Tire Nirvana!
« Reply #20 on: September 17, 2004, 13:00:28 »
I have a question. As the speed rating of the tire increases so too does the side wall flex? When would this be evident below 100MPH between an H rated tire & an HR rated tire?
Re: Tire Nirvana!
« Reply #21 on: September 17, 2004, 15:33:25 »
Just as an aside, it looks like the tread design of the new Coker reproductions of the Phoenix tires is remarkably similar to that of the 15 year old Michelin XW4 WSW 185R14 tires on my 230SL. I have been increasingly concerned about these, due to their age, and have been casting about for WSW replacements.  The problem has been that WSW tires in this size have all but disappeared, and any new old stock that I have been offered have been on the shelf for a bit and have a wider white wall that is not acceptable for show.  My XW4s are fairly quiet at highway speeds, but I can't really comment on their handling as I don't chuck the car around much in deference to their age.  The XW4 was standard equipment on the big Lincoln Town Cars in the 80's and early 90's and were both durable and handled well, so it should probably be comforting to think that the Michelin plant down in Mexico is basing the Coker Phoenix lookalikes on what appears to be the XW4 carcas and molds (with the necessary cosmetic modifications to the outer side wall!).  Looks like I may have pay a visit to the Coker website!
« Last Edit: September 17, 2004, 15:37:39 by Mike Hughes »
Re: Tire Nirvana!
« Reply #22 on: September 17, 2004, 15:44:32 »
Just to repeat what I picked up before: tires age (dry out?) with time, not just with wear. Someone once mentioned tires over 5 years old typically will not be in the best of shape, regardless of the mileage on them. So if you drive your car very little, your tires may look new, but in fact may perform poorly and could be dangerous to drive with. One of my old tires, with more than half the thread still left, disintegrated on the highway, losing a big piece of surface on the highway one day. For this reason, I would never purchase "NOS" tires.
Re: Tire Nirvana!
« Reply #23 on: September 20, 2004, 09:01:12 »
...excellent point Cees, and one I've believed for some time.  It is important to remember that TIRES are not the only thing made of rubber in the car.  Most of the suspension is "bushed" with rubber; ditto for mounts of various kinds.  When you've gone through the time and trouble of removing some of these items made of rubber during any kind of service/restoration/rebuilding, think twice about replacing old rubber.  Do you really want 35 year old rubber replaced back into the car when it took you 6 hours to get the darn part out?  Just something to think about...
Re: Tire Nirvana!
« Reply #24 on: September 20, 2004, 10:16:50 »
In Dubai, (I was told) all new tyres sold now have dates on them. Anyting over three years old will not pass the annual test for road worthiness. Of course they have VERY HOT summers and rubber deterioration is much accelerated.
I just cancelled my order for those expensive Michelins  :)
